94 s-10 engine problems
Google
Web AF
s0231198
01-28-2005, 12:59 PM
I have a 94 s-10 with a 2.2, it has sort of a hesitation or misfire to it when you are going up a hill or accelerating, I have changed the spark plugs( several times), coil packs, wires. and it still does it. and everytime I change the plugs one of them the electrode is gone, like it's burnt off, and they are platinum plugs, it happens after maybe 10,000 miles and is never the same cylinder. no one has been able to tell me what maybe causing this hesitation or why it's burning the plugs off. any help would be greatly appreciated, Rob
OverBoardProject
01-28-2005, 01:15 PM
Check your timing, you might have to adjust it a little off the mark in 1 direction or the other for the best setting
gregg565
01-28-2005, 01:17 PM
sounds like you have an air leak somewhere on your intake leaning your mixture that will cause hesitation and smoked plugs
s0231198
how do you check the timing, since there is no timing marks?
Google
Web AF
