chevette how hard is it to put in a small block chevy?
Google
Web AF
mike5721947
01-27-2005, 08:29 PM
well looking to buy a wrecked chevette and put in a older 305 or 350 small block and am wondering what has to be changed and what is a pain to do (firewall clearence and trans clearence) and engine mounts?
will the rear end hold? or should i get a stronger one? what would fit under the car?
tom3
01-28-2005, 04:51 PM
Might jump over to www.chevytalk.org and do a search for chevetteroadwarrior or crw user name. This is a guy in So.Ohio who had just what you're planning. Pretty head turning car too. Don't know if the guy is still active but you might find his Email address. Pretty nice guy from what I saw.
mike5721947
01-28-2005, 08:20 PM
nope cant do that wont work and i just want to know about if it fits with just minor mods (no redoing the whole engine compartment)
IFIXCARZ4U
01-29-2005, 12:41 AM
Anytime you attempt this type of engine swap the is considerable time energy and money spent with disappointing results. there is NO easy way to do this type of swap
victimizati0n
01-30-2005, 08:02 AM
um, acually it CAN be done.
They made a chevette into a race car (origional panels and frame) and it has a small block in it
tom3
01-30-2005, 11:46 AM
Probably be ahead to find an aluminum head v6 to put in it, but after all is said and done, you still have a Chevette. I'd sure rather put my time and money in a V8 S10 or something like that.
karagmile
04-22-2006, 09:48 AM
shouldn't be major headaches. don hardy (i think) stuffed in a 4.3, the 90* v6, with some minor (or no) tuning of shock towers; since the 'vette had an L4, the v8 should fit no sweat. you will have issues with hood clearance on pre-77s; hardy recommended the '77-9. i'd use v8 monza/clone front springs & brakes. the th-180's a bit weak for a v8; i'd swap in the -200 out of a '78-88 g-body (monte/clone), & use the GN Regal shift kit. 10-bolt is strong enough, unless you're going nutz on power; recall, it was behind the 280hp GNR. given the choice, i'd fit a 5.3 or buick 215 or 350, instead, rather than the heavier sb chevy.
karagmile
04-22-2006, 09:55 AM
shouldn't be a problem. don hardy (i think) swapped in a 4.3, the 90* v6, with no problems; the 'vette had an L4, so v8's no sweat. you may need to hammer the shock towers a bit. you will get hood clearance trouble on pre-'77s; hardy recommended '77-up. i'd use v8 monza/clone front springs & brakes. the th-180's a bit weak; i'd use the -200 from a '78-88 g-body (monte/clone), with the gn regal shift kit. the 10-bolt's strong enuf; recall, it backed the 280hp gnr. i'd prefer a 5.3 or buick 215 or 350, rather than the heavy sb.
Google
Web AF
