Code PO304 # 4 plug misfireDcrusoe 01-27-2005, 01:13 PM Hello all, My code reader is showing a P0304 - #4 plug misfire. Ie changed spark plugs (shop tuned it and did the work) Ie checked the gap on the plug pulled the spark plug wire and can see a good spark flying from it. yet it is still misfiring. I put a compression gage on it and getting 120 to 140 PSI. And I out of ideas. I do not want to take it to a shop untill I know what they need to do with todays prices to just start searching untill they find it. Any pointers of what to look at next? Please! stomana 01-30-2005, 10:41 AM check the ignition coil blazee 01-31-2005, 06:44 AM If you're getting good spark it is probably the injector. (either clogged or not working properly) Run a bottle of injector cleaner through and see if that helps. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
