Prelude with s2000 rims.
MechanisM1
01-25-2005, 11:00 PM
Has anyone considered getting 4 front wheels from the 1st gen s2000 and putting them on a 97+ Prelude?
Prelude: 205/50 16x6
S2000 Front Wheel: 205/55 16x6.5
Wheels were stolen off my car, I was considering doing this.
knorwj
01-25-2005, 11:39 PM
doesn't matter so much that the rim and tire size is similar. what matters the most is if the bolt patterns are the same.
MechanisM1
01-25-2005, 11:41 PM
They are both 5x114.3
SiGNAL748
01-26-2005, 06:49 PM
I've seen it done. It looks pretty clean, provided the car's lowered. Just make sure you swap out the tires on the s2000 wheels for 205/50 too keep the same overall diameter as your old wheels.
MechanisM1
01-26-2005, 07:47 PM
So I shouldn't buy 205/55 (Which would fit the s2000 wheel)?
What is wrong with that..
SiGNAL748
01-26-2005, 07:53 PM
You can keep the 205/55 if you want. 205/50 and 205/55 both fit, provided they're R16. I'm just saying that it will slightly offset your speedometer's accuracy if you keep the stock s2000's 205/55. Putting on 205/50 would return it to your original diameter, so that there is no speedometer offset.
MechanisM1
01-26-2005, 08:51 PM
Ah ok, thanks for the info!
SiGNAL748
01-26-2005, 09:28 PM
No Problem. Post up some pics when you get them. I'd like to see them :)
