Anyone know off hand............Sp3cops70 01-25-2005, 10:30 PM 1. Which fuse number is for the rear defrost?? 2. I turn it on and nothing happens so i think it is the fuse....if its not could it be the connections itself on the rear window??? 3. Where do i get replacements?? He kid, bigl, and gtp warrior....thanks for ya'lls help...i changed the crankshaft pos. sensor today and the fuel filter and the PCV...its running as smooth as a babies azz!! Ya'll know the answers off hand?? By the way it is a 97 GP GT 3.8 Liter. GTPWarrior 01-25-2005, 11:02 PM check the " Lines" in the back window and see if therre is any separation inside the window,(looks like a Blown fuse with a real small burn mark) I have seen this happen on a few rear windows. not sure about wiring/fuse locations on 97 and 98 but check inside glove box right hand side of the glove box where you pull the cubby hole out. there should be a bunch of fuses there. R DEf should be bottom row third from the right. But CustomKid will know for sure. 30 amp Sp3cops70 01-26-2005, 08:39 AM check the " Lines" in the back window and see if therre is any separation inside the window,(looks like a Blown fuse with a real small burn mark) I have seen this happen on a few rear windows. not sure about wiring/fuse locations on 97 and 98 but check inside glove box right hand side of the glove box where you pull the cubby hole out. there should be a bunch of fuses there. R DEf should be bottom row third from the right. But CustomKid will know for sure. 30 amp Thanks... vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
