Eec Codes
VALDI7
01-25-2005, 09:09 PM
Hi!! I Was Checking My Brothers Maxima For Codes Because His Cel Was On. I Plug In My Obdii And Did Not Find Any Codes. I Think The Obdii Is Malfuncting Because All It Said Was E, Like In Error!! Any Sugestings Are Appreitiated.
Nahkapohjola
01-26-2005, 12:37 AM
take batt off to reset ECU
see: http://www.cardomain.com/memberpage/748507/14
infinman
01-27-2005, 10:57 AM
What type of scanner are you using?Never heard of a "e" code.Don't erase memory{disconnect battery} until you properly diagnose code.Whenever you scan for codes and find one code only donot erase.Diagnose.If you find more than one code ,erase all then see which codes return.You may be dealing with old codes that were never erased after previous repair.
