were is my horn ? limited 89
BlueCivic83
01-24-2005, 05:56 PM
lol my horn wot work now. i think it's a disconnected wire but i can locate it under the hood could you tell me were it is located ? i think it happened to me bfore .
tonsoffuns
01-24-2005, 08:43 PM
i think it is behind the grill
BlueCivic83
01-24-2005, 09:23 PM
wow thats noit gonna be easy...
chili
01-26-2005, 03:40 AM
Acutally you have 2 of em one on each side of the jeep under the fender mud shields.....but where is the relay locate ? :banghead:
Saudade
01-26-2005, 07:27 AM
The relay is under the driver side dash, near the fuse block, taped to a section of harness.
chili
01-26-2005, 10:36 AM
Thanks is there a way to test that relay or just head to pick and pull grab one a try it out ?
:1zhelp:
runuover
01-26-2005, 10:54 AM
:1zhelp:
i would try the pick and pull it cant be that hard. :evillol:
Stick89
01-27-2005, 05:53 AM
On an 89' the horns are behind the front bumper.
1 on pass. side
1 on dr. side
Horn relay should be somr where by the drvr side kick pad..
chili
02-02-2005, 11:00 AM
1 on pass. side
1 on dr. side
Ok newb question.....what color is the factory relay? found 3 blue, black and white......
Replaces the blue on and no change....
going to crawl in deeper and see what happens when i replace the white one next :banghead:
Chili
chili
02-04-2005, 01:46 AM
Chili
OK finally found it and the horn works ! :bananasmi as for the location its (on my jeep) up on the firewall almost under the dash and its a whitish color....
Good luck all
Chili
