CODE 26 - Fuel Measuring Divce Rich
BenGera
01-23-2005, 04:20 PM
1989 Toyota Camry
check engine code 26 - Fuel Device Failure (RICH)
I replaced catalytic converter about a year ago
I replaced oxigen sensor about two months ago
I replace EGR valve & sensor two months ago
Failed emmission test (before the check engine came on..) on HC & CO
Is the TOO RICH error enough to cause the emmission failure (Gross Poluter)
Is the Measuring device adjustable? Where is it and how?
Is it a sensor that needs replacing? Where is it?
What is the sensor found below the oxigen sensor on the exhaust manifold?
Many Thanks & Best Regards
