97 jetta gls
jdmr123
01-23-2005, 03:15 PM
I have a 97 jetta gls automatic. everything works on the car except when i try to turn it on it wont even crank. I was previously told to check the alarm module and to connect the 5 and 6 red and red and black wires but there is no 6 wire. I've disconnected the ecu the alarm and to nothing. I remember before if you would disconnect the battery and plugged it back in the alarm would go off. It doesnt even do that just one honk and that's it. I have closed the doors and set the alarm and I open the door and the alarm doesnt go off, it still shows as if the alarm is on. Please help..........
boschmann
01-24-2005, 12:05 PM
Automatic or Manual transmission? First check to see if you get 12V+ to the small red/black wire on the starter solenoid when the key is in the start position (alarm module connected).
jdmr123
04-21-2005, 01:45 AM
it is a manual transmission.
breddi
06-20-2005, 09:43 PM
you said it is a manual tranny? well then do try to make sure the clutch is pressed all the way to the floor or you may have issues, ebcause there is a switch that cuts the ignition if the clutch is not fully depressed
