wiring help please!!poorskater 01-23-2005, 02:47 PM ok, so here are some pics of wat i just got. I couldnt find a pic of the box i bought, but heres a link to it. http://www.qlogic.ws/2003/home THen i have 2 these subs http://img.photobucket.com/albums/v119/oneafterdark/66349985TS-W300R.jpgand this amp..... what do you think would behttp://img.photobucket.com/albums/v119/oneafterdark/f700.jpg the best way to wire it? i use to have two tens, and i would just wire one to the other then bridge them. Should i do that here? Another thinkg, the back panel that is above the rear passenger seats, is rattleing like you wouldnt believe.. how would i take care of that so i can have my subs on but no rattle? killah_xft 01-24-2005, 03:02 AM put some dynamat on the back shelf there, that'll take care of the rattle.. and you can wire those subs in two ways.. each has it's drawbacks, and advantages.. you can daisy chain them, or you can run them in parallel. we need to know the resitance of the subs, and the AMP's load rating.. running them in parallel is almost your best bet.. is each sub has a 4 ohm resistance, and your AMP has a 2ohm resistance capability run them in parallel for a 2ohm resistance. which makes for a good match.. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
