93 JGC - Replaced Steering Gearboxblackbird24 01-21-2005, 07:48 PM Hi there, I replaced the steering gearbox on my JGC. I bleed the system and topped up the fluid. The fluid is clear and consistent. No foaming or bubbling. My problem is when I drive the vehicle the steering feels sloppy. The vehicle wants to wander and the steering is not precise. It seems to me that there is a delayed response from when I turn the steering wheel and when the road wheels actually turn. Would the above problems be eliminated with a simple wheel alignment or is there some adjustments that needs to be made with the steering gearbox? Im also wondering if it could be a weak power steering pump? Any thoughts, advice or help would be much appreciated. Thank you. JDPascal 01-21-2005, 07:51 PM try this thread http://www.automotiveforums.com/vbulletin/showthread.php?t=345891 I'd recommend going tighter a 1/4 turn at a time JD blackbird24 01-21-2005, 08:52 PM As always thanks for the prompt response JD. You seem to have hit it on the head with that post. I will give it a try this weekend. Thanks again. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
