How do you check the tranmission fluid?mpfootball_aa 01-21-2005, 11:50 AM How do you check the transmission fluid of the honda passport. ive looked everywhere and i can't find a dipstick amigo-2k 01-21-2005, 12:10 PM 1994 mpfootball_aa 01-21-2005, 12:21 PM yes it is rodeo02 01-21-2005, 12:34 PM This is in regards to a 1994 4x4 with auto trans? I didn't think they went dipstickless on the 4L30E until 1996-ish?!?! If you dont have an ATF dipstick, you will have two plugs facing downward on the larger trans pan. The plug higher up on the pan is the fill/level check (stamped/recessed into the rear right corner of pan). ATF should just dribble from this plug on a hot, idling truck, in neutral on a level surface. G/luck Joel mpfootball_aa 01-21-2005, 03:31 PM This is in regards to a 1994 4x4 with auto trans? I didn't think they went dipstickless on the 4L30E until 1996-ish?!?! If you dont have an ATF dipstick, you will have two plugs facing downward on the larger trans pan. The plug higher up on the pan is the fill/level check (stamped/recessed into the rear right corner of pan). ATF should just dribble from this plug on a hot, idling truck, in neutral on a level surface. G/luck Joel Where is the trans pan located? I couldn't see any noticible plugs. surferfletch 01-21-2005, 05:16 PM There are 2 hex head bolts on the bottom of the gray pan on the 4L-30E tranny. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
