is this all i need to have a working turbo
unknownluder69
01-20-2005, 10:52 AM
I found a kit that i customized and this is what it comes with.This turbo kit includes a turbo header, a wastegate (either internal or external), a turbo, and an intercooler. All this for like $1500. is this a good deal or am i getting ripped off b/c i still need other parts that I would have to buy seperatly. all feedback is appreciated.the kit i looked at buying included an external bov (35mm) and the piping for the exhaust system i.e. downpipe and a custom 3" exhaust system was going to be bought seperatly. I mean was there any thing major that i have not included that i would for sure need. To start off im goin to run around 5-7 pounds of boost. I am goin to get a gauge pod for the side part of my window, and a computer system setup for managment, but not till I know i have everything to make it work properly
-Jayson-
01-20-2005, 12:37 PM
Oil Feed and Return Lines, i dont know if that requires a pump as well. Possible fuel mods.
psychorallyfreak
01-22-2005, 09:58 PM
Normally, you'd just tap a pressure line (usually right from the oil filter) to lube the turbo, and drill a hole in the side of your sump to plumb in the return line.
DO NOT FORGET an oil cooler!
beyondloadedSE
01-22-2005, 10:19 PM
Thats why your engine creates oil pressure. :grinyes: No oil pump is required for a turbo...your engine will do the work for you.
I guess for $1500 are these parts new or used? What turbo? What intercooler? Water/air or air/air?
Your going to need a bov, probably a bigger fuel pump...DO NOT get a fuel pressure regulator. Do it the right way and upgrade fuel injectors. If the wastegate doesnt come with a 5-7 pound spring, then your probably going to want to get some sort of boost controller. And of course, youll need some sort of engine management. Dont forget all the misc hoses, clamps, elbows, etc.
unknownluder69
01-22-2005, 10:40 PM
the site is http://turbocalculator.com/sale-turbokits.php i have an h22a i was going to get the t3 super 60 with 35mm bov/wastegate (i forget which) the lardest intercooler, I think by spearco. has anyone here put one of these on an h22? if so wat were the results? does anyone here think i should just buy a complete kit for like 3500 so i get everything or stay with this?
