gas tank buzzing
Google
Web AF
chembrad
01-20-2005, 09:23 AM
1994 S15 Jimmy V6 Vortec (Vin W) auto everything
Just replaced down to the lower intake manifold gasket and replaced the heater core. When I reinstalled everything, my gas tank "buzzes" constantly. I know it is the fuel pump. But why would it buzz non-stop?
Did I miss a connection somewhere that will cause this?
rlith
01-20-2005, 09:30 AM
The buzz is normal, if it stops then your fuel won't pump..:) GM fuel pumps are known to buzz loudly...
chembrad
01-20-2005, 10:05 AM
Dang. What a pain.
Is there an aftermarket replacement that is quieter? I don't like the buzz. Although you can only hear it when you are near the gas cap, I still don't like it.
rlith
01-20-2005, 10:32 AM
Nope, even the after market ones buzz... It's inhearant to the design...Welcome to chevy world..:D
yotermanic
01-20-2005, 11:53 PM
I've found the aftermarket ones are usually even louder!
jsgold
01-21-2005, 12:05 AM
Ditto. Just replaced mine with a NAPA "top of the line" brand, and it makes more noise than the old one EVER did.
BlazerLT
01-21-2005, 02:10 AM
Dang. What a pain.
Honestly bro, you going to change a pump because it is too loud?
Little ridiculous don't you think?
chembrad
01-21-2005, 02:34 AM
I just didn't know what it was supposed to sound like. My cars fuel pumps don't make any sound like that. :eek:
Cut me some slack! This is my first truck and I have only had this Jimmy for like 2 months and I already have replaced the cpi, nut kit, both valve cover gaskets, lower & upper intake manifold gaskets, water pump, thermostat, the heater core, all vacuum and coolant hoses.
I had to flush the radiator several times before I got rid of most of the gunk in the coolant system.
I'm still working on getting rid of all the rust stains on the cab floor carpet.
I also installed a Sony CD player which ROCKS! Only 22W but it puts out more sound than I like to listen to. :iceslolan
Nothing like jumping into a new vehicle with both feet eh?
BlazerLT
01-21-2005, 02:44 AM
Hehe, yea, all I was saying is don't look into changing the normal stuff, just enjoy the truck. :D
chembrad
01-21-2005, 12:07 PM
... just enjoy the truck. :D
You got that right! This baby shines up pretty nice.
Now all I have to do is figure out how to keep my wife from driving it. :cwm27:
I don't think the line "I'm not sure if it is trustworthy yet" line will work much longer. :grinno:
wolfox
01-24-2005, 11:52 AM
Leave a fish wrapped in a ton of newspaper in the jack compartment. Sooner or later, you will get this indellible scent that will last for far longer than your marriage. ;) I love chemical warfare...
...Did I mention that this may be one of the reasons why I am still single, yet? :lol:
BlazerLT
01-24-2005, 04:26 PM
lol, nice
WiCkEdLtTahoe
07-06-2005, 06:54 PM
I recently also changed out my fuel pump, cause it was going out on me and dien, and then 2 days later it completely died......and now that ive got a new acdelco which is a gm brand name part... it seems to buzz really loud.... but i dunno i kinda like it.... sounds like i got a high flow fuel pump or somthing hahaha :smokin: :smokin: :smokin: :smokin: :smokin:
dreamweaverzink
07-13-2005, 06:33 AM
You can replace the padding on the fuel tank straps and any other place the tank touches anything with new felt (roofing felt will work if you can't find the replacement padding at a parts store) This will help a little, especially if the padding is missing entirely. You can also spray undercoating on the floor pans which will reduce the noise even more. Just depends on whether it is annoying enough to drop the tank again???
zeppelin2112
07-13-2005, 12:31 PM
I've had the same annoying buzz... knew it was the fuel pump, and definitely didn't look forward to replacing it... glad to know something evil wasn't happening in my gas tank. Thanks!
BlazerLT
07-13-2005, 04:38 PM
That is not the noise we are talking about.
We are talking about the fuel pump whirring noise which is normal.
dreamweaverzink
07-13-2005, 06:59 PM
Yes, the noise is normal from the constant whirring of the pump, however, if the dampening padding is missing or severely worn, that "normal" noise is amplified about 40 times through the body of the vehicle. The body and tank itself will act as a resonator which amplifies the sound much more than one might realize. If you undercoat between the tank and body it also will help dampen this normal noise. The sound won't stop, but will be much less noticeable inside the passenger compartment. It is kinda like playing an acoustic guitar; if you wrap a blanket around the body of the guitar, the sound is dampened tremendously. The body of your vehicle resonates sound in the same way. Try it next time you drop your tank, it really does help a little.
BlazerLT
07-13-2005, 10:52 PM
The noise is not caused by vibration, it is the sound of the pump motor working.
Google
Web AF
