02 dakota, headlight out, a/c prob
latoyasboy
01-19-2005, 05:28 PM
headlight out on passenger side, bulb works, no voltage to it, can't find a headlight fuse either.
heater blower only works when turned to hi, does not work in med or low, any ideas?
theFREAKnasty82
01-19-2005, 11:55 PM
For the headlight fuse, it's usually in the passenger compartment by the drivers side end cap, you should see a fuse saying LH hdlght or something along that line. As far as the blower motor only working on high, sounds like a bad blower motor resistor.
jack_92342
03-05-2005, 02:13 PM
The LT/HD fuse is located in the distribution panel in the engin compartment on the left side.
my fuses are ok but nether haedlite works, after I installed a trailer brake controller. I had to unplug a large wiring harness to plug the controller harness. So any one, what did I screw up when I pluged the large harness back in?
