Transmision questionmemo27 01-19-2005, 04:15 PM I've notice in my 2002 Impala LS that when I start driving it all the gears chande smoothly. The way that they're suppost to change. Then, after driving it for a while when the first gear changes it doesn't feel as smooth. It has like a little kick to it. Like it pulls the car a little bit. It changes gear find it just feels a heavier kick when it changes. It's just in the first gear, after that it's smooth. I don't know if it's normal or I'm having problems. Anybody has any ideas. 3.4imp 01-19-2005, 05:17 PM my impala did the same thing. I think it might be some kind of throw out bearing or something. chevy rebuilt my tranny (they said, like i believe those f*%^#ing liars.) :) Pat_OD 01-19-2005, 06:10 PM is it still under warranty? memo27 01-20-2005, 10:30 AM No is not under warranty, but it stoped doing it. Yesterday worked just fine. With no problem. Hopefully it stays that way. memo27 01-26-2005, 02:00 PM I bought my car from one of my friends. He bought the extended warranty on the car up to 100,000 miles. The car right now has 60,00. But I want to know since he sold me the car if the warranty is still good. If I can use the warranty in case that it breaks down. gramsof1 01-26-2005, 06:58 PM Ok folks, Here is what our tranny is doing in our '01 with 51,000 miles. Having read a few other posts, I am NOT encouraged. I am not even sure if we have the "bad" tranny, but it sure sounds like it. We have the 3.4 size engine. A few weeks ago we started noticing a slightly harder shift, at time, not all the time. The we have a fairly sttep hill and we noticed when we pulled into the parking space there was s distict burning odor - like electrical to me. Then when going up the hill, we could hear a whining which seems to get worse with more load against the trans. Of course our extended warranty ended at 50,000 miles. This morning my husband took it into GM dealer (these are the same ones who had to do all the BCM replacements when the *&^*%^ car wouldn't start. That problem seems to be fixed and at their nickel). Anyway, they said it would probably need around $2,000 in repairs but they couldn't say for sure until they looked at it. He was told it wasn't dangerous so he said he would have to talk to the pocketbook and go from there. Then he went to a very respected tranny repair shop. He took the car out for a test drive and took it up "the hill". Of course it shifted just fine, didn't whine or smell. On returning to the shop, my husband noticed the back of the lot had a slight rise so he had the guy drive to there and take his foot off the brake. Of course the car rolled backward. It has done this since the day we bought it. We have complained and complained about it to the GM dealer but they maintain, it is normal. We have never had an automatic that wouldn't "hold" itself on a slight rise without having to hold the brake. Thsi guy said there is definitely something wrong. He thinks it may be the solonoid or even the computer setting may be wrong. He's guessing about $600.00 for him to check it all out and if it needs fixing, which includes a flush and refill. My husband told the tranny guy about what the GM dealer had said and he said that GM does NOT repair trannys. They send them out or have the tranny replaced. At least this one does it that way. We don't know what to think. And we wonder if the backsliding problem is a problem with this transmission in particular. i tols my husband I was going to research on the web and if it is in any way linked to the problem we are having now - it will be a visit to the owner of the dealership along with some very nasty words and a letter to GN. All thoughts are welcome! Thanks in advance micali 01-26-2005, 07:42 PM mine won't hold on a hill. It's these new trannys that they put in the impalas. mine wouldn't upshift on the hwy unless I let off the gas a little thenit would. I had a smell that was from the CAT being clogged and I had the CAT replaced and the car runs fine and shifts smooth. IFIXCARZ4U 01-29-2005, 01:19 AM I am a GM technician and it really jerks my chain when people bad mouth dealerships. you peons have no clue what it takes to work on todays vehicles. It is complicated and demading work which you crybabies could never do if you had to. Now as to the holding on a hill test it is a big scam for the independent transmission shop. Show me in any service repair manual for any vehicle built a hill holding test and i'll quit my job and sing show tunes for a living!!!! As far as having a hard shift take the vehicle to a Qualified Dealership (Ask around for people who had good luck with a particular Dealer) and just have them check for any stored DTC's. These transmissions are very sensitive to shifting problems. if there are any codes set it raises line pressure to maximum to avoid further damage. If there are no codes set there is NO PROBLEM. As far as overhauling transmissions if it is under warranty it must be removed and dissassembled for inspection if it is cheaper to rebuid it then that is what must be done NOT just replaced. And yes ALL GM transmissions are rebuilt by someone else stictly for GM mostly in Mexico, THANKS NAFTA. If it is a customer pay transmission overhaul it usually is replaced rather than rebuilt, only because you get a better warranty with a replacement 3 years 50,000 miles, as compared to 12 months 12,000 miles for an in house overhaul. NOW SHUT YOUR CAKE HOLE YOU WHINERS!!!!!!!!! gramsof1 02-08-2005, 02:05 PM I am a GM technician and it really jerks my chain when people bad mouth dealerships. you peons have no clue what it takes to work on todays vehicles. It is complicated and demading work which you crybabies could never do if you had to. Now as to the holding on a hill test it is a big scam for the independent transmission shop. Show me in any service repair manual for any vehicle built a hill holding test and i'll quit my job and sing show tunes for a living!!!! As far as having a hard shift take the vehicle to a Qualified Dealership (Ask around for people who had good luck with a particular Dealer) and just have them check for any stored DTC's. These transmissions are very sensitive to shifting problems. if there are any codes set it raises line pressure to maximum to avoid further damage. If there are no codes set there is NO PROBLEM. As far as overhauling transmissions if it is under warranty it must be removed and dissassembled for inspection if it is cheaper to rebuid it then that is what must be done NOT just replaced. And yes ALL GM transmissions are rebuilt by someone else stictly for GM mostly in Mexico, THANKS NAFTA. If it is a customer pay transmission overhaul it usually is replaced rather than rebuilt, only because you get a better warranty with a replacement 3 years 50,000 miles, as compared to 12 months 12,000 miles for an in house overhaul. NOW SHUT YOUR CAKE HOLE YOU WHINERS!!!!!!!!! You know, I would take your advice and go to a qualified dealer if there was one. but since there is only 1 GM dealer in the area, it makes it a bit hard, especially when you have dealt with them in the past and are not totally satisfied with the results. It's easy for you to sit here and write mean mouthed comments to concerned people who have not had good luck with their Impalas. We bought this car in good faith and we expect the transmission to last longer than 50,000 miles. We are not 20 year old who have never had a car before. We have had approximately 8 new cars in the 42 years we have been married. Not ONE of them had a tranny go out while we had them and we put over 50,000 miles on all of them. It seems to me when any number of people have the same problem with a vehicle, regardless of the brand, they is probably a problem with that vehicle. Now if GM won't stand behind their product, as in our case, 1400 miles past warranty, it doesn't say much for them. I think it is very "unfair" of you to criticize our very real concerns. Also, not everybody in the world can just fork over 85 to 90 bucks an hour to see what the problem might be. In our case, when both of us are unemployed, it would mean a bank loan and try and get one when you are out of work. Downsizing is a _ itch! You at least are probably working. 403 02-08-2005, 06:03 PM I have a 2001 impala w/ police package and 4t65e trans,which I bought new in 2001. I am the only driver. I bring it to the dealer for all maintainance including oil changes every 3000 miles. At 42,000 miles the car felt like it had a broken motor mount.I brought it to the dealer and was told it had a broken input carrier assy and 4th clutch hub stripped out.Since the same dealer has performed all the maintainance they contacted GM who covered $3000.00 of the $3500.00 bill as a good will repair.While I don't think a heavy duty transmission in a car that is not abused should break at 42000 miles,if you have receipts and are loyal to your dealership ask them to check with GM for help with the repair.You know, I would take your advice and go to a qualified dealer if there was one. but since there is only 1 GM dealer in the area, it makes it a bit hard, especially when you have dealt with them in the past and are not totally satisfied with the results. It's easy for you to sit here and write mean mouthed comments to concerned people who have not had good luck with their Impalas. We bought this car in good faith and we expect the transmission to last longer than 50,000 miles. We are not 20 year old who have never had a car before. We have had approximately 8 new cars in the 42 years we have been married. Not ONE of them had a tranny go out while we had them and we put over 50,000 miles on all of them. It seems to me when any number of people have the same problem with a vehicle, regardless of the brand, they is probably a problem with that vehicle. Now if GM won't stand behind their product, as in our case, 1400 miles past warranty, it doesn't say much for them. I think it is very "unfair" of you to criticize our very real concerns. Also, not everybody in the world can just fork over 85 to 90 bucks an hour to see what the problem might be. In our case, when both of us are unemployed, it would mean a bank loan and try and get one when you are out of work. Downsizing is a _ itch! You at least are probably working. bermis519 02-09-2005, 09:54 AM Well to the person who called us whiners....ya i understand that it's hard to work on todays cars. Well when i get a car, i want something that is going to last many years and not have a bunch of problems. I for a fact have every right to "whine" about me car, because i have had problems after problems. Had the tranny ripped apart, the motor, and a huge list of parts replaced. If you consider this normal maintances then ya maybe you should go sing show toons for the rest of your life. People spend a lot of money on cars and they have every right to bitch when something happens to their cars. I take offense to your post because of the problems i have had, and then for you to sit there and call us whiners. GM cars are shit and i will not buy another one for awhile. I have but about $6500 bucks into mine. If you want to hear what i have been through then email me because i'm would be more then happy to tell you all about it. Just don't give peope a bunch of crap for complaining about their cars because....after thats what this forum is for!!!!! Mike gramsof1 02-11-2005, 09:23 PM I have a 2001 impala w/ police package and 4t65e trans,which I bought new in 2001. I am the only driver. I bring it to the dealer for all maintainance including oil changes every 3000 miles. At 42,000 miles the car felt like it had a broken motor mount.I brought it to the dealer and was told it had a broken input carrier assy and 4th clutch hub stripped out.Since the same dealer has performed all the maintainance they contacted GM who covered $3000.00 of the $3500.00 bill as a good will repair.While I don't think a heavy duty transmission in a car that is not abused should break at 42000 miles,if you have receipts and are loyal to your dealership ask them to check with GM for help with the repair. Well if our problem had started at 42,000 miles it would have been under waranty still. It ran out at 50,000 miles or 5 years. The problem started at 51,000 miles. Yes we have had the car to this shop many times and they have done a lot of work on it. all warranty, so they are very familiar with it. No we haven't taken it to them for oil changes because they charge too much but we have kept records of when we did the changes, etc. They told us our warranty was over, period. They also gave us a tol free number to set up an appointment - this is a number in California - to schedule an appt in Washington. Go figure. this dealership has gotten too big and the customers have become numbers instead of customers. This is not the first car we have bought there either. It may just be the last though. Those 100,000 mile Kia and Hyundai warranties are looking better all the time. Their cars are looking pretty nice too. finalshaft 02-27-2005, 12:56 AM 72,300 mi Tranny went out. Told by tranny shop, sell or rebuild. Is that any way to treat an '02 Imapala? Especially after I suffered the CatConverter problem (replaced at 49,500mi) and the Coolant leak at 64,000mi. NYC IFIXCARZ4U 03-09-2005, 12:21 AM Well to the person who called us whiners....ya i understand that it's hard to work on todays cars. Well when i get a car, i want something that is going to last many years and not have a bunch of problems. I for a fact have every right to "whine" about me car, because i have had problems after problems. Had the tranny ripped apart, the motor, and a huge list of parts replaced. If you consider this normal maintances then ya maybe you should go sing show toons for the rest of your life. People spend a lot of money on cars and they have every right to bitch when something happens to their cars. I take offense to your post because of the problems i have had, and then for you to sit there and call us whiners. GM cars are shit and i will not buy another one for awhile. I have but about $6500 bucks into mine. If you want to hear what i have been through then email me because i'm would be more then happy to tell you all about it. Just don't give peope a bunch of crap for complaining about their cars because....after thats what this forum is for!!!!! Mike OH BOO HOO IFIXCARZ4U 03-09-2005, 12:22 AM You know, I would take your advice and go to a qualified dealer if there was one. but since there is only 1 GM dealer in the area, it makes it a bit hard, especially when you have dealt with them in the past and are not totally satisfied with the results. It's easy for you to sit here and write mean mouthed comments to concerned people who have not had good luck with their Impalas. We bought this car in good faith and we expect the transmission to last longer than 50,000 miles. We are not 20 year old who have never had a car before. We have had approximately 8 new cars in the 42 years we have been married. Not ONE of them had a tranny go out while we had them and we put over 50,000 miles on all of them. It seems to me when any number of people have the same problem with a vehicle, regardless of the brand, they is probably a problem with that vehicle. Now if GM won't stand behind their product, as in our case, 1400 miles past warranty, it doesn't say much for them. I think it is very "unfair" of you to criticize our very real concerns. Also, not everybody in the world can just fork over 85 to 90 bucks an hour to see what the problem might be. In our case, when both of us are unemployed, it would mean a bank loan and try and get one when you are out of work. Downsizing is a _ itch! You at least are probably working. I'm sorry if u are an unskilled MORON gramsof1 03-22-2005, 02:12 PM I'm sorry if u are an unskilled MORON I think your insults are totally uncalled for and if I were the moderator of this forum - YOU would no longer be allowed to post. all you can do is call concerned people names. For YOUR information, I am not an "unskilled moron" as you put it so nicely. I am a grandmother who is now retired because no one wants to hire a grandma no matter how good they are at the job they do. Thank God YOU are not anywhere near where I live because I wouldn't take a broken down rattletrap to you to be fixed and I feel sorry for any of your clients. THEY can do better than you! As I write this, our '01 Impala is at the tranny shop. When they drained the fluid and took out the filter, it is covered with bits of metal, both brass and steel. So something is messed up inside this wonderful tranny. Do you have a smart aleck answer to that Mr. IFIXCARZ4U? No I didn't take it to the Chevrolet dealer. I don't trust them. Oh we called the dealershiip repair shop and told them of the findings and their comment - There aren't any service bulletins about it - sorry, no can help. Update on the tranny - they had to replace the torque converter core - that's where the metal shavings on the filter were coming from. Got the car back yesterday - to the tune of $2516.39. today we are taking the parts and the bill to our local Chevrolet dealer. If they wont' do anything about it,we will be sending all of the information to GM. It is a crock that this should happen with a transmission with under 51 miles on it! impalaguy2 03-27-2005, 10:38 PM Well to the person who called us whiners....ya i understand that it's hard to work on todays cars. Well when i get a car, i want something that is going to last many years and not have a bunch of problems. I for a fact have every right to "whine" about me car, because i have had problems after problems. Had the tranny ripped apart, the motor, and a huge list of parts replaced. If you consider this normal maintances then ya maybe you should go sing show toons for the rest of your life. People spend a lot of money on cars and they have every right to bitch when something happens to their cars. I take offense to your post because of the problems i have had, and then for you to sit there and call us whiners. GM cars are shit and i will not buy another one for awhile. I have but about $6500 bucks into mine. If you want to hear what i have been through then email me because i'm would be more then happy to tell you all about it. Just don't give peope a bunch of crap for complaining about their cars because....after thats what this forum is for!!!!! Mike you probably bought a lemon of some pubilc auction, i had problems with my previous 00 camry (everyone told me get toyota. piece if shit, used engine cost $1500 compare to $500 for an impala) had to pay $2500 for engine change, u can't really tell today whats good or not. u just have to get it at a reputable place. don't judge GM from your bad experience with one car. they sold over a million units. as far as chevys i think they are pretty good. i sell used parts and gm have a low request for major parts like motors and trannys. impalaguy2 03-27-2005, 10:48 PM I think your insults are totally uncalled for and if I were the moderator of this forum - YOU would no longer be allowed to post. all you can do is call concerned people names. For YOUR information, I am not an "unskilled moron" as you put it so nicely. I am a grandmother who is now retired because no one wants to hire a grandma no matter how good they are at the job they do. Thank God YOU are not anywhere near where I live because I wouldn't take a broken down rattletrap to you to be fixed and I feel sorry for any of your clients. THEY can do better than you! As I write this, our '01 Impala is at the tranny shop. When they drained the fluid and took out the filter, it is covered with bits of metal, both brass and steel. So something is messed up inside this wonderful tranny. Do you have a smart aleck answer to that Mr. IFIXCARZ4U? No I didn't take it to the Chevrolet dealer. I don't trust them. Oh we called the dealershiip repair shop and told them of the findings and their comment - There aren't any service bulletins about it - sorry, no can help. Update on the tranny - they had to replace the torque converter core - that's where the metal shavings on the filter were coming from. Got the car back yesterday - to the tune of $2516.39. today we are taking the parts and the bill to our local Chevrolet dealer. If they wont' do anything about it,we will be sending all of the information to GM. It is a crock that this should happen with a transmission with under 51 miles on it! Maybe the trans went bad because u granny drive so slow the trans got tired of u and had a meltdown.......lol but seriously it can happen at any milage to any car, i've seen a jetta with 32 miles, i repeat 32 miles come back to the dealer with a bad trans. MCO_Death 03-29-2005, 10:48 AM I'm sorry if u are an unskilled MORON Very Professional, Which dealer you work for bud? You certinly are not giving them a good image as well as other dealership shop workers. I know you people know your crap, so why not use your knowledge to give some helpful advice rather than call people who are seeking help morons. guenther 03-30-2005, 09:16 PM IFIXCARZ4U, The tranny on my '00 had a bad pressure control solenoid valve and it didn't throw a code. You repair dorks saying that if you can't reproduce the problem or there isn't a code so there's nothing wrong is a bunch of BS. I've proven my local Chevy dealer wrong numerous times. I have driven my LS for 110,000 miles and I know when something is wrong. Why don't you go back to the dealership and whip one off with some 10W30 because obviously your boyfriend isn't taking care of your needs at home. Boo hoo, grease money! filipg 04-17-2005, 09:42 PM As far as I know GM dealerships do NOT rebuild transmissions. I called many withing towing-distance of Princeton NJ - they will only put in remanufactured. AAMCO (and other chains) will do R&R and will also tow you for free if you decide to do the repair with them. My Buick Century with 23K miles is getting said treatment as we are speaking. The 4T65E's from some years seem to have a design/manufacturing error and the TCC valve experiences abnormal wear and begins to leak. That valve is responsible for 'applying' the gear and when it leaks, the pressure is incorrect and clutches wear or do not apply correctly. It EVENTUALLY (in my case much sooner than that word implies) leads to (for my Buick) TSB # 03-07-30-017 which involves replacing the valve body (or sonnex kit - you want the later!) and all damaged parts which, for me, were ~$1200 (just parts!). Even with that, the dealer is still $1000 more. I don't know what warranty the dealer's tranny is but most chains offer 1yr/12K with a 3yr/36K for more ($400). Other than that, we like the car == Other than that, Mrs. Lincoln, how did you like the play :-) Cheers, Fil impalaguy2 04-19-2005, 08:03 PM As far as I know GM dealerships do NOT rebuild transmissions. I called many withing towing-distance of Princeton NJ - they will only put in remanufactured. AAMCO (and other chains) will do R&R and will also tow you for free if you decide to do the repair with them. My Buick Century with 23K miles is getting said treatment as we are speaking. The 4T65E's from some years seem to have a design/manufacturing error and the TCC valve experiences abnormal wear and begins to leak. That valve is responsible for 'applying' the gear and when it leaks, the pressure is incorrect and clutches wear or do not apply correctly. It EVENTUALLY (in my case much sooner than that word implies) leads to (for my Buick) TSB # 03-07-30-017 which involves replacing the valve body (or sonnex kit - you want the later!) and all damaged parts which, for me, were ~$1200 (just parts!). Even with that, the dealer is still $1000 more. I don't know what warranty the dealer's tranny is but most chains offer 1yr/12K with a 3yr/36K for more ($400). Other than that, we like the car == Other than that, Mrs. Lincoln, how did you like the play :-) Cheers, Fil ok TCC is the torque converter clutch.... nothing to do with shifting, the TCC apllies at high speed and locks the converter to the engine speed thus saves gas. You can feel it when You go on the highway it's like the car goes into 5th gear. on new models trannys like the 4T65E it engages also in lower gears. You probably have a problem with the presure control regulator and it is effects the smoothness or firmness of the shifts. it is common for all trannys to give some kind of metal "dust" lets say - I don't care if it is a buick or a mercedes it will have some wear with time, even after 23K! that fine metal debris sometimes can cause a restriction at the control valve and cause "not so normal" shifting. That's why I always recomend to my customers to replace the Trans fluid and filter at least once every year (and not as the manufacturer says.. 100K... forget about that), this will prevent that kind of problems in the future. everyone change engine oil at 3000 miles but the trannys always get neglected. it is one of the hardess working parts in the car, why not take care of it too?? impalaguy2 04-19-2005, 08:16 PM IFIXCARZ4U, The tranny on my '00 had a bad pressure control solenoid valve and it didn't throw a code. You repair dorks saying that if you can't reproduce the problem or there isn't a code so there's nothing wrong is a bunch of BS. I've proven my local Chevy dealer wrong numerous times. I have driven my LS for 110,000 miles and I know when something is wrong. Why don't you go back to the dealership and whip one off with some 10W30 because obviously your boyfriend isn't taking care of your needs at home. Boo hoo, grease money! You got to check it at a differest dealer... or a reputable shop 110,000 mile - something will be bad in the trans unless you took extreme care of it-like changing fluid and filter once a year. if you didn't maintain the trans properly you have a reason to complain... the fluid will probably be brown and the unit clutches and other valves worn - tell the dealer to take the pan down and look at it - You can tell immidiately if something is wrong and that even the morons in your dealership would see i'm sure! well unless ray charles is your mechanic.... MCO_Death 04-20-2005, 08:03 AM You got to check it at a differest dealer... or a reputable shop 110,000 mile - something will be bad in the trans unless you took extreme care of it-like changing fluid and filter once a year. if you didn't maintain the trans properly you have a reason to complain... the fluid will probably be brown and the unit clutches and other valves worn - tell the dealer to take the pan down and look at it - You can tell immidiately if something is wrong and that even the morons in your dealership would see i'm sure! well unless ray charles is your mechanic.... Maybe Ray IS my mechanic... not really... My tranny is just breaking down at 160k, only counting down now, I expect it to fail inevitably, but won't do anything about it until it does. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
