Gas mileage on your van?
Marine2
01-19-2005, 11:22 AM
Wonder how well the Dodge Caravan does on mileage compared to other makes. Tell us what size engine and year you have and what kind of mileage your getting.
HiRez_L
01-19-2005, 02:59 PM
88 Caravan 3.0 liter gets 28 mpg
89 Caravan 3.0 liter gets 28 mpg
89 Caravan 3.3 liter gets 24 mpg
94 Caravan 3.6 liter gets 20-21 mpg
HeadlessHorseman
01-19-2005, 03:02 PM
'96 Grand Caravan LE 3.8L 4-speed automatic...
14-18mpg around town
24-27mpg on the highway
19-21mpg average
HiRez_L
01-19-2005, 03:10 PM
Oh, yeah, I should mention that highway driving is all I do with my vans.
427v8
01-21-2005, 08:40 AM
97 GC, 27 mpg 75% highway
And thats doing 70mph...
Matimus
01-21-2005, 09:52 AM
2002 3.8L T&C Limited w/AWD:
45KMi Avg: 17.21 mpg
Best Tank Ever: 23 mpg
The heated seats when used cost 1 mpg !!!
cary leonard
01-24-2005, 12:43 AM
98 voyager, 113,000 miles; 4 cylinder. gets 22 HW and 18 city
ibandaey
03-16-2005, 02:34 AM
1998 Dodge Grand Caravan LE 3.8. 143K I get 20-24 MPG average. When we went on a trip to California all highway we got 26-30mpg!!! She was a lot younger then though!!
jryocum
03-16-2005, 11:53 AM
2005 Caravan SXT 18.4 city , 25.6 highway..3.3 liter v6
hayesbcajh
03-16-2005, 12:25 PM
02 Voyager 4cyl. 35k miles. 18/20 city, 24/25 highway.
rlaeromech
03-23-2005, 02:50 PM
2005 3.3 v6 - full tank - 360 miles, worst than my Ford F-150 V-8
what size is the full tank
zander5
03-23-2005, 07:53 PM
96 g voyager replaced plugs, wires, both O2 sensors and direct air to the throttle body Gas milage the best 20 mpg
Marine2
03-27-2005, 10:39 PM
Well, I have a 2005 DGC, with a 3.8 engine. I have about 1,200 miles on it so far and have yet to get 20mpg. This last tank was 19.98 mpg and it is the best so far and that is with about 80% freeway driving
HiRez_L
03-28-2005, 04:24 PM
It's interesting how varied our mileages are, some of us routinely get 20MPG or better, some of us never do . . . makes you wonder how tight the quality control is on the engines.
Matimus
03-28-2005, 06:49 PM
HiRez L,
Interesting comment on QC. However, I think the real answer is engine displacement and options, and the ability to accurately figure gas mileage. Or the odometers lie and chalk up lots of miles!
BTW, you can't go by the computer mpg in these vans as my T&C overestimates the mpg by .5 mpg
minimum.
HiRez_L
03-28-2005, 10:38 PM
None of mine are new enough to have a computer that figures the mileage for me . . . I have to do it the old fashioned way, fill up every time and divide the number of miles traveled by the number of gallons pumped . . .
Cobra_Sam
03-29-2005, 08:17 AM
HiRez L,
minimum.
As I am sure you all know a new van will suck gas till she is run in ... However all of you with older girls with 100 or more thousand miles on should be getting good mileage ... if not you should be asking yourself when last did I replace the catylitic converter and the Oxygen sensor. The oxygen sensor (when faulty) will screw with your mixture and the catylitic converter when getting old (clogs up) will start restricting the exhaust flow out of the cylinders causing higher temperature around the exhaust valves causing them to burn.
I just replaced my Cat, found a regular fit one at Autozone for under $80 where it was $175 everywhere else.
Good luck .. you all have good taste in cars.
dno36
03-31-2005, 09:36 PM
We have at least 2 on the road at all times, totalling about 95K/yr. Maintainence and efficiency are very important.
Synthetic lubricants all around, except if we have a leaker.
Here is what I have had saved.
87 3.0 GCV 3spd - 20.6 all around 24 highway. 1st off the line. 265K
89 3.3 GCV 4spd - 19 all around 24 highway.
91 3.3 GV 4 spd - 19.6 all around 24.5 highway. 435K miles to DOA trans
91 3.3 std V 4 spd - 19.6 all around 24.2 highway
92 3.3 GV 4 spd - 20.1 all around 25.2 highway
94 3.0 GV 4 spd - 19.8 all around 25 highway
'96 3.0 std 3 spd - 21.2 all around 25.5 highway
'97 3.3 GCV 4 spd - 20.3 all around 25.2 highway
We live in a rural/ suburban area 60 miles from Chicago, and use the vans for everything, and I mean everything.
(o:
DNO.
jgionet
08-23-2005, 02:13 PM
I find I get awful mileage on my van... howeverI suspect my gas tank is buckled a little since I can only put it 55L of fuel when the owners manual says I have a 75L tank. On a full tank I can only get roughly 450KM'sum. I would think it would be better than that. I drive it %50 highway/%50 city/town driving. I've replaced the plugs, air filter and change my oil when I have too and put some high-end fuel cleaner in the tank once in a while. I have a 96 Caravan 3.3L. Overhaul it runs well.. just don't think I'm getting good KM's with it.
I'm baffled.
-JG
