Isuzu Rodeo Coolant
98Rodeo4x4
01-19-2005, 01:56 AM
Mechanic advise me that I should buy the coolant for my Rodeo directly from the dealer. Apparently, there is a BIG difference if you buy regular coolant from the local shop compared to the coolant at the dealership.
Is this true?
And if I do buy from the local shop, what tpe should I be looking for?
Thanks
Brian H.
98' Isuzu Rodeo 3.2V6 4x4
txsoulfly
01-19-2005, 03:14 AM
Is this true?
Thanks
Brian H.
This was taken from a TSB # SB96-14-L002
ISSUE DATE
JANUARY 1996:
Isuzu has determined that propylene glycol-based engine coolants, such as Safe Brands' Sierra engine coolant, will perform adequately under most vehicle operating conditions. As a result, propylene glycol-based engine coolants may be used in Isuzu vehicles.
A few important points to remember regarding propylene glycol-based engine coolants:
^ Freeze/boil point levels for propylene glycol are different than for ethylene glycol.
^ To accurately determine the freeze/boil protection level, it is imperative that the coolants not be mixed.
^ Prior to adding propylene glycol engine coolant to the cooling system, all ethylene glycol coolant must be removed.
^ When changing the coolant to propylene glycol, be certain to thoroughly flush the heater core and block as well as the radiator.
HTH Clear as mud if you ask me. :screwy: :rofl:
