97 Tahoe Dies When Put It In GearWRUTTER 01-18-2005, 06:27 PM I Have A 92 Tahoe Runs Great In Park When I Drop It In Gear Dies Instantly.. I've Tried To Feather The Gas Pedal To Keep It Running No Luck Any Ideas troy1 01-18-2005, 06:34 PM I bet you have a bad torque converter Sol. in the trans. WRUTTER 01-18-2005, 06:36 PM I bet you have a bad torque converter Sol. in the trans. BRAND NEW TORQ AND TRANS troy1 01-18-2005, 06:37 PM still can be bad WRUTTER 01-18-2005, 06:40 PM still can be bad I DID NEED TO HEAR THAT......BEFORE I PULL THE TRANS OUT AGAIN IS THERE ANYTHING ELSE IT COULD BE OR ANY TROUBLE SHOOTING I CAN DO troy1 01-18-2005, 06:40 PM how long ago was is built troy1 01-18-2005, 06:41 PM dont have to pull the trans WRUTTER 01-18-2005, 06:46 PM how long ago was is built I just bought trans and coverter 1 week ago ran fine truck sat for about 3 months prior to installing the new trans and torq.... I even blew out all the lines and resovoirs... i thought maybe feul problem??? WRUTTER 01-18-2005, 06:46 PM dont have to pull the trans how do I check it troy1 01-18-2005, 06:47 PM rebuild or junk yard trans? WRUTTER 01-18-2005, 06:48 PM rebuild or junk yard trans? rebuild troy1 01-18-2005, 06:49 PM is it under warranty WRUTTER 01-18-2005, 06:50 PM is it under warranty 2yr troy1 01-18-2005, 06:50 PM can you take it there to get it fixed? WRUTTER 01-18-2005, 06:53 PM can you take it there to get it fixed? no I had it ship it from Illinoise...... troy1 01-18-2005, 06:57 PM ok pull the pan and at the front of trans near tc you see two round sol. and a square one with 2 10mm headed bolts covered up buy one round one. thats the one you want. you have to remove the round one but leave it connected there is a clip in the small slot use a pick to get it out cover it with a rag cuz it will shoot out pull the square sol. out and let it hang there put the pan back on and fill it back up and put it in gear troy1 01-18-2005, 06:58 PM put the round one back in also WRUTTER 01-18-2005, 07:03 PM ok pull the pan and at the front of trans near tc you see two round sol. and a square one with 2 10mm headed bolts covered up buy one round one. thats the one you want. you have to remove the round one but leave it connected there is a clip in the small slot use a pick to get it out cover it with a rag cuz it will shoot out pull the square sol. out and let it hang there put the pan back on and fill it back up and put it in gear what do you mean by sol troy1 01-18-2005, 07:05 PM solenoid WRUTTER 01-18-2005, 07:09 PM solenoid thanks troy1 01-18-2005, 07:09 PM http://www.transtarindustries.com/newparts.asp Go to sku# 5T-173 see the square solenoid in front thats what you want troy1 01-18-2005, 07:10 PM let me know if this works enginetune 01-22-2005, 02:28 AM Unplug it from the trans. Or pull the fuse for the TCC. If it doesnt release, send it back or call them and see if they deal with anyone local. No sense dealing with aggrivation you don't have to. WRUTTER 01-23-2005, 11:46 AM let me know if this works iT DID NOT WORK i ALSO RE FLUSHED THE SYSTEM AS WELL ???????????????????????? WRUTTER 01-23-2005, 11:48 AM Unplug it from the trans. Or pull the fuse for the TCC. If it doesnt release, send it back or call them and see if they deal with anyone local. No sense dealing with aggrivation you don't have to. tHANKS i WILL TRY IT.............i ALSO REPLACED THE SOLINOID ON IT IT WASNT IT AS WELL ??????????? troy1 02-02-2005, 02:17 PM should not be able to replace that solenoid My next guess would be a pluged orfice or a stuck valve. I would send it back they should pay for shipping or see if its got a nation wide warranty troy1 02-02-2005, 02:20 PM my info was flawed I thought you had a electronic tranny (its only a 92 my bad) guess you dont have all the solenoids but test is the same sorry. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
