Knocks OVER BUMPS whats going on?
tjhtomo
01-18-2005, 03:05 PM
Hey I bought this jeep from my unkle. Right now I have a problem where the front end is nocking over the bumps sounds like some thing is loose. Cant really find anything. Please Reply if ya know whats going on.
dksob81
01-18-2005, 06:49 PM
BALLJOINTS - best bet would be bad balljoints.
there is a way to test them, jack the front end up (front wheels off the ground) and place it securely on jackstands. then place a 2x4, crow bar, long pipe, etc under one of the wheels and look closely at the balljoints as you pry up on the tire - see if there is any noticable play, then do the other wheel the same way, sometimes the castle nut comes loose and the steering knuckle will slip up and down the on the balljoint - you will notice this when prying on the wheel.
Cam7
01-19-2005, 05:26 AM
If its not the Ball Joints Check the Sway Bar Links. Some have a ball and socket type ass. when worn makes a popping noise.
tjhtomo
01-24-2005, 10:31 AM
so I whould need to repace the ball joints if it was doing this correct?
dksob81
01-24-2005, 01:46 PM
Balljoints would be the most likely problem, but Cam though up another possiblility.
