99 Howling
Google
Web AF
BOTTLEFEDCUTLASS
01-18-2005, 08:59 AM
My problem is... When I have it in 4-wheel or auto I'm getting a howling noise. (Pretty Loud) When I'm in 2-wheel I can still hear the howling but it's very very faint. I'll tell you what I've done so far.... I replaced the front u-joints and put new bearings and seals in the front differential. Any ideas?
TorinoGT69
01-18-2005, 09:26 AM
Could be uneven tire wear or could be internal problem with one of the differentials.
BOTTLEFEDCUTLASS
01-18-2005, 09:40 AM
When I have the truck in the air it still makes the howl. Tires are not on the ground! The sound is coming from the front of the truck.
busta
01-18-2005, 10:35 AM
well i was going to say tie rods are shot because if they were the tire's whould ride with lots of toe in or toe out causing tons of tire road noise but since you still have it with wheels of the ground i say check the front wheel bearing assembly and they are not servicable so they entire hub would need to be changed and sorry but these babies are not cheap! good luck
BOTTLEFEDCUTLASS
01-18-2005, 10:39 AM
I've checked the wheel bearings and all look good there. I'm thinking ring a pinion?
TorinoGT69
01-18-2005, 11:29 AM
If it does it in the air sounds like a worn, damaged or inproperly setup ring and pinion.
BOTTLEFEDCUTLASS
01-18-2005, 11:34 AM
It sounds like something is worn in the diff. But when everything was apart it all looked good.
skipr
01-20-2005, 12:40 AM
Front wheel bearings?? I thought they were sealed constant velocity joints. And unserviceable like Busta stated. I could be wrong for the year/model, but 98 1500 4WD's are sealed CV joints.
Google
Web AF
