coldheat, WTF?potsdamcartel 01-16-2005, 05:50 AM anyone use the coldheat soldering iron? i'm thinking about buying one. does it do everything a regular soldering iron does? do you need some kind of special low melting point solder or something? how does it work? ECP 01-16-2005, 05:53 AM They work just like a regular gun. You dont need special solder. The only diffirence is that it cools down in a matter of seconds so you can touch it right after you just soldered and you wont get burnt. Its more for a safty feature. But it works great clawhammer 01-16-2005, 11:35 AM anyone use the coldheat soldering iron? i'm thinking about buying one. does it do everything a regular soldering iron does? do you need some kind of special low melting point solder or something? how does it work? I wouldn't try it. There is no metal known to man that can cool down that quick. So I'm thinking: either it doesn't cool down that fast, or 2. it doesn't work properly. Just use a regular soldering iron. uranium235powered 01-16-2005, 03:12 PM WHY just WHY would you want to buy one? I've invested myself into a Radioshack solder iron for about $12.00 Works flawlessly. Save yourself the extra few dollars to buy more solder vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
