89 4x4 blazer s-10 tahoe
Google
Web AF
blazerboy2005
01-13-2005, 10:43 PM
I have a 89 4x4 blazer s-10 tahoe 4.3 with 215537mi and still runing strong I just got it last week for a cool $300 To day I replaced all the ball joints one front axle and heater core for $300 not bad right? and now everything is in working order any way i was reading some other threads andi know about the cpi and the tbi but can any one tell me what the cpc is i guess i have a tbi cpc is that right and another issue is my gagues like my oil pressure is always 1/4 from the top my temp is alway low and gas gague wont go all the way up when the tank is full it says its 3/4 full any help would be great.
BlazerLT
01-14-2005, 02:13 AM
Nice score, that is indeed cheap.
blazerboy2005
01-14-2005, 12:24 PM
yeah it was a good score but i cant find any one that sells a brush guard for it
BlazerLT
01-14-2005, 12:34 PM
http://search-desc.ebay.com/blazer-brush-guard_Parts-Accessories_W0QQsofocusZbsQQsbrftogZ1QQcatrefZC12Q QfromZR10QQsacatZ6028QQcatrefZC6QQftsZ2QQftrtZ1QQf trvZ1QQsadisZ200QQfsopZ1QQfsooZ1QQcoactionZcompare QQcopagenumZ1QQcoentrypageZsearch
not looking too hard are you......
blazerboy2005
01-15-2005, 12:50 AM
can any one help me with my gague problem or tell me what cpc means
BlazerLT
01-15-2005, 02:49 AM
CPC, never heard of it.
What are you meaning?
blazerboy2005
01-15-2005, 01:19 PM
ok forget cpc can any one help me with my gague problem
blazerboy2005
01-16-2005, 12:44 PM
so no one can help me at all
molehole
01-16-2005, 01:06 PM
When you mean 1/4 from the top do you mean the guage is all the way to the right? If it is it sounds like you have good oil pressure. If it never moves then it could be the sending unit to the guage itself. As for the temp guage temp should be somewhere around 1/4 to 1/2 way up on the guage (like 195-205 degrees) or so depending on your car. If it stays stays cold then you may need a thermostat because the car is not heating up properly. If it heats up it could be the temp sending unit. Fuel guage problem may be either the floater is stuck in the tank or the sending unit is bad. I believe the sending unit is right in front of the gas tank. BTW if none of the guages appear to be working, have you checked for blown fuses. I believe there is a fuse for the guages. Good Luck and keep us posted
blazerboy2005
01-17-2005, 11:20 AM
well the oil pressure gauge jumps from the 1/2 to about 3/4 going by the lines on the gauge when i give it gas is when it dose this. the temp gauge stays all the way down all the time. the gas gauge wont go all the way up when tank is full it stays at least 1/4 from the top I think it could be a ground but where are the grounds for the gauges
molehole
01-17-2005, 12:10 PM
When you start it up does it goes about 1/2 way or so and then jump when yo give it gas. Sounds to me like it is operating normally unless it never goes below the half mark. The gas guage probally will work with a new sending unit which is located back near the tank with some wires coming from it. Temp guage is most likely a sending unit but if you are having problems getting the car to warm up or if you dont have heat it is probably the thermostat, which is pretty simple to replace. I'm not sure where the grounds are but they may be on the back of the instrument cluster. Good luck
blazerboy2005
01-17-2005, 01:47 PM
the truck runs fine temp wise. and is the sending unit in the gas tank oh and by the way hater replacing my heater core the damn blower moter went out last night haw hard is it to replace i think the barings rotted out of it
BlazerLT
01-17-2005, 04:19 PM
Also, you might have a thermostat stuck open.
zipdrive38
01-17-2005, 09:00 PM
go to www.jcwhitney.com
Google
Web AF
