2002 T&C Lx vibration and pulls to rightwrightbrigade 01-12-2005, 09:07 PM Just bought this minivan for my wife. It's pretty nice. At highway speed it vibrates through the steering wheel, must be front tires bad. I noticed on the Goodyear tires it has slight buldges on the sidewalls. Like it's a broken belt inside the tires. So I guess I'll be replacing them, good news it they are about due anyway. What about the pull to the right. Is that tires also? Could it be out of alignment alread at 62000. Thanks GTP Dad 01-13-2005, 06:23 AM When you have the tires have the vehicle lined up anyway. The cost is reasonable and will help with both gas mileage and tire wear. The pull to the right could be due to the tires especially if the tires are due for replacement. HiRez_L 01-13-2005, 08:27 AM Plus, if you have it aligned after getting new tires, they'll tell you if your CV joint is bad, which is the next most likely cause of vibration on these after tires. TorinoGT69 01-13-2005, 09:21 AM Pull is more than likely the tires. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
