my car is shaking when pressing brake pedal to stop at low speedseanxu 01-10-2005, 11:26 PM the problems happened just this morning. In the past two days, i drove more than 300 miles. there was no problem. when the transmission shift is at D position and I go forward at a very low speed( just after release the brake), less than 5 miles, then I press the brake pedal to stop the car. Before the car stops, the car will shake once. and i can feel the vibration is from the under of the car. Just like i move the transmission shift from D to P when car is still moving. But when the transmission shift is at R position and I go backward, everything is fine. no shake when I press the break pedal to stop the car. I haven't try at high speed. because I am scared to do so. anyone has ideas? hope it is not the problem of the transmission. Thanks Mangoamerican 01-11-2005, 02:05 AM could be your hub... check it out by jacking up your car and pushing the wheel back and forth, i say this because the same thing happend to me.. the brake was actually forcing the caliper and wheel out, causing my brakes to be outta whack and that odd clunk, like my rear end was locking up Classicrocjunkie 01-11-2005, 02:16 AM That is a hard thing to diagnose.. it could be a caliper or rear drum that is hanging up and releasing after you come to a stop. You also might need to have your transmission just flushed and refilled. The cable might also need to be adjusted that controls the shifter and what drive its in. It could be bordering Drive and neutral.. Its just a hard thing to diagnose with out actually being there. seanxu 01-11-2005, 03:44 AM I am a new driver. i don't understand why i can't see any symptom before. the problem appeared so suddently. I am just confused. is it very popular for cars? thanks tonymwc 01-30-2005, 07:45 PM yes a lot of cars do that suddenly. noshun 01-31-2005, 09:50 PM check that your wheel lugs are tight! It could be a lose wheel! hopeless4life 01-31-2005, 10:40 PM Or it could even be your first experience with shitty GM ABS brakes noshun 01-31-2005, 11:51 PM Or it could even be your first experience with shitty GM ABS brakes Yeah they are always fun! come spring I'm unhooking the sensors on mine! Cuts in too soon and works awful! Only car I ever had ABS on and will hopefully be the only car I ever have with it! s10blazerman4x4 02-01-2005, 07:09 AM i agree with you hopeless i was gonna say the abs because i know thats how it is in blazers below 10 and that thing will spit sputter do anything it wants seanxu 02-01-2005, 12:27 PM After I drove about half mile, the problem was gone. until now, it didn't appear again. some mechanians said it might be the rear brake was not working well because of rust. after driving, the rust was gone. then everything is fine. is that possible? thanks big dude1 02-01-2005, 12:51 PM Oh man i thought i was the only one who hated his ABS lol every time i stop in my drive way my wheels lock up cuz its all mud... its that slippery mud with a texture similar to say... vaseline... i hate that feeling the peddle gives off... noshun 02-01-2005, 08:34 PM After I drove about half mile, the problem was gone. until now, it didn't appear again. some mechanians said it might be the rear brake was not working well because of rust. after driving, the rust was gone. then everything is fine. is that possible? thanks If it's fairly warm the friction surfaces of both the rear drums and front rotors can get a light covering of rust. This isn't likely to be the problem though as it would only be a very light amount of surface rust and not anything particulalry abrasive unless the car had been sitting for a long time. The type of rust you'll get can be wiped off with your finger! ps27 02-05-2005, 05:55 PM My 96 skylark, does something similar. It shakes the whole car when I hit the brakes above 40 mph. The pedal and steering wheel also vibrate, it has gotten worse. Problem is very bad increasingly at higher speeds. But something else not related as far as I know, My check engine and ets off lights came on and won't go off. Any help would be appreciated. Thanks noshun 02-06-2005, 01:21 PM My 96 skylark, does something similar. It shakes the whole car when I hit the brakes above 40 mph. The pedal and steering wheel also vibrate, it has gotten worse. Problem is very bad increasingly at higher speeds. But something else not related as far as I know, My check engine and ets off lights came on and won't go off. Any help would be appreciated. Thanks Your brake rotors are warped or at least one is and need replacing, you'll need pads also. do both sides together, always do!! Your Check engine light, is the car running any different at all? have you noticed a drop in fuel consumption, power etc.....? ps27 02-08-2005, 04:14 PM Your brake rotors are warped or at least one is and need replacing, you'll need pads also. do both sides together, always do!! Your Check engine light, is the car running any different at all? have you noticed a drop in fuel consumption, power etc.....? The brakes are new all the way around. The tires, shocks, struts are also new. ps27 02-08-2005, 04:18 PM The brakes are new all the way around. The tires, shocks, struts are also new. The only notice is lights, I see no difference in power or fuel economy. These lights came on a couple of times before together but went off in a couple of days. Also the Abs light comes on at 70, and dosen't go off until I restart the car. noshun 02-08-2005, 11:42 PM The brakes are new all the way around. The tires, shocks, struts are also new. Teh it souds like they need re-tightening. Or you ABS is f*cked, which would probably explain the Check eng light! Check the sensors at the front calipers. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
