Heater only works on High..
justrelaxing
01-10-2005, 11:57 AM
My heater will only work when it is on high. All other settings it is quiet and the fan never runs. I looked at the fuses inside the car and the ones under the hood and none are broken. Would this be another fuse someplace, switch is bad, or can the motor or something go wrong on low and not high?
Any help would be great.
chuckieb
01-10-2005, 12:04 PM
The fan speed control resistor network is located behind the blower moter on the passenger side. Mine went out a while back. It's a bear to replace, but removing the blower motor will make it easier
Renegade2k
01-15-2005, 11:46 PM
I had the same problem Don't try and do this unless you are flexible
