Right Headlight
OUIPOLO
01-08-2005, 03:28 AM
The Right Headlight On My 94 J30 Goes On And Off While Driving And Sometimes When I Start The Car Only The Left One Turn On. Can Anyone Help Please On What Might Cause This And What I Can Do To Fix It.
THANK YOU
Speedy_1234
01-09-2005, 03:19 PM
What is is a little box in the firwall in the driver side that cause the prongs not to work meaing not to touch so there will be power but you can take it to a tv. guy and tell him/her to solider to getter or if you want to buy other just where the tire is the driver in front wheel on the roof of the tire there is three screws 10mm should take them off and once doing that you can take it off on the top in the firewall
Speedy_1234
01-09-2005, 03:30 PM
open the hood firewall drive side is a black box go to the driver wheel on top of the tire is three screws take them with 10mm key or socket(deep) take the box off the fire wall and open it take the top off then check all prong are not touch them put the side light on you will hear a click sound then go to the light (headlight) you will hear a click sound you should see all the prongs are touch if you see one that is not touching push the prong :nono: don't push it with a metal thing do it with you finger push it if you see the light(rightlight) trun on that is you problem the box now if the right light does not turn on go open the hood go to the fuses check if both head light fuses work ok they work and still nothing try the light blubs if they are good if the headlight blubs are good it can be that black box take it off and you can take it to the tv man tell him to put soldeir in it or do like i did bought a new one which costs :2cents: in my hometown 50.00
