2000 express 5.7L fouling plugs won't startexpress 01-07-2005, 10:25 PM I have a 2000 express 5.7L. Won't start pulled plugs soaked with gas. Installed new plugs same thing. I'm going to check for spark tommorow. Any other ideas??????????? robscherer 01-11-2005, 04:07 PM Guessing you found no or weak spark. Bad distributor??? Do you have to go thru the wheel wells to get the plugs out??? RNRea 04-27-2005, 12:01 AM Check plug wires, cap & rotor (you'd think that they'd still be good for only being a few years old). Check coil. Or, if it was like mine, replace the ignition module inside the distributor. Pull the cap and rotor off and it is a small, squarish thing that screws into the distributor body and has a wire (or two? I can't remember now) that come out of the distributor. Replacement is $40-$70 from parts store, not difficult to do. Also a good time to check the rotor and distributor contacts - might want to replace them too. Good Luck. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
