View Full Version : A'pexi N1 Damper ExV Coilover for 89-98 240sx
zilvia14
01-05-2005, 06:36 PM
Hi Guys,
Just want to know if anybody is interested in Apexi Coilover. I just spoke to this company to see if they can give us a discount if we have enough buyer for the Coilover.
If you have questions, you can contact me below :
Email: Jason_performance@yahoo.com
TEL: 917-578-8180
A'pexi N1 Damper ExV Coilover (2005 Newest Coilover)
Application for 89-94 (S13) and 95-98 (S14)
MSRP - $1590.00
The more people the cheaper it will cost us ! Let's make this happen!!!
1- 5 will be $1399 Shipped
6-10 will be $1269 Shipped
http://www.deus-x.com/files/1KsxpRESFID43RESapexi.jpg
Product Features
- Full Coil Over Threaded Base
- Monotube Shock Absorber utilizing a 44mm diameter piston
- 32 way ride adjustment
- 62 mm direct wound spring
- 22mm Strut type rod (All others use a 12.5 mm rod)
- Quick Adjuster, Coil Over Adjustment Wrench included
- Exclusive Upper Mounts
- Aluminum Brackets (Strut utilizes steel brackets)
- One Year Warranty for (Oil, Gas)
Product Points
- APEX Integration Exclusive Design
- Compression and Spring rates specially matched for US road conditions
- Ride settings calibrated for excellent ride quality and sports driving
- Incorporates the same N1 Damper Series high precision valve
and piston for accurate settings.
- The Quick Adjuster allows for easy compression ratio (ride) adjustments
- Strut types incorporate a pillow upper mount with camber adjustments
- Other types utilize a rubber upper mount to eliminate noise
and preserve ride quality.
- Includes dust boot to prevent oil leaks
- Includes spring seats to minimize noise
Related Links
Participate in thousands of discussions at AutomotiveForums.com! Registration is absolutely free.
