87 Ford F-150 turns but wont spark
Google
Web AF
numberonefatguy
01-05-2005, 04:06 PM
I have a 1987 Ford F-150 and it cut out on me while I was driving it and would not start again though the starter would turn. I thought it was a problem with the ignition module and replaced that but it continued to do the same thing. I then thought it was a fuel related problem, and replaced the fuel filter and checked the pumps but the fuel system is working fine. I have new plugs and a new distributor cap on it but im still not getting spark. Dont know what the problem is. Any help would be appreciated.
FORDTRACMAN
01-06-2005, 08:01 AM
#1Guy
Remove distributor cap and crank engine,to make sure shaft is moving.
Report back!
With that info someone will be able to help.
numberonefatguy
01-08-2005, 01:52 PM
Nope the shaft inside the distributor is not rotating so what do I need to do?
97chevyman
01-08-2005, 04:17 PM
Well, pull the distribrator, and check the gear on the bottom, make sure the little pin did not break, otherwise might have broken a timing chain.
FORDTRACMAN
01-08-2005, 08:41 PM
Sorry I didn't get back sooner.Chevyman is right, thanks
numberonefatguy
01-08-2005, 11:29 PM
do you guys now how to un-bolt the distributor
Google
Web AF
