Powerstroke using 10 Qts oil in 100 miles
Google
Web AF
wolftng
01-03-2005, 06:03 PM
This is a question on a 95 E-350 with a 7.3 powerstroke. When I got it it was smoking and banging, but I replaced injector seals and then it was great. Then I had the oil changed at Ford and after about a hundred miles it would not run any more. It was 10 quarts low. I thought maybe they forgot to fill it up, but then after another hundred miles same thing. This does not smoke and no visible signs of major oil leaks. Any ideas anyone???!!! :confused:
ModMech
01-04-2005, 01:58 AM
Injector seals...again. The oil is going into the fuel. Not exactly common, but it does happen.
StillTruckin
01-04-2005, 03:31 AM
Yes, warm it up and the exhuast color will be discolored, since the oil is getting into the fuel and combusting.
ModMech
01-04-2005, 10:20 AM
The most reliable way to tell if you have oil in the fuel is to remove the fuel filter cover and check the fuel color. If it is brownish/blackish you definately have oil in the fuel.
Google
Web AF
