Low Fuel Indicator Light Issue....
djjc76
01-02-2005, 02:44 AM
I have a 2001 Tacoma S-Runner and the Low Fuel indicator light doesnt glow when I am low on fuel. Is there a fuse that needs to be replaced? Thanks...
Juan
[email protected]
Juan
[email protected]
Flash75
01-03-2005, 08:42 PM
I don't think there is a fuse for that light alone. It may share a fuse with some other circuits. If the fuse is bad you should see some problems other than the low fuel indicator light. Sorry I cannot give a better answer, I don't have access to a wiring diagram. Maybe moving your question to the top will get a better response.
BostonGuy - 001
01-03-2005, 09:24 PM
Sounds like the problem could possibly be a bad relay in the dash. The relay may not be completing the circuit to activate the indicator. I would recommend reviewing the wiring diagram and test the electrical circuits.
Flash75
01-04-2005, 05:48 PM
Although I don't have a wiring diagram for a 2001 I did look at a Haynes drawing, it covers up to 2000, and there is no relay in the circuit. As I suggested there is a shared fuse. It is the gauge fused and if it is bad all gauges should also be dead.
I have a 2004 entended cab SR5 and have not seen the low fuel light even though I have run it until the gauge shows empty. However the tank is supposed to hold 16 gal. and it takes less than 14 gal. to fill the tank when the gauge shows empty. My question is, does my truck actually have a low fuel indicator? The owners manual dances around the issue by saying, "If the fuel warning light comes on fill the tank immediately" or words to that effect. I don't yet have a shop manual to check the circuit.
Clifton
Clifton
yamaharollinhard
12-19-2005, 05:16 PM
alright so heres a question for ya, how much dose the tank hold? i thought i read that it was a 12.5, but then i saw 15, and i have the same problem of the fuel indacator, it gets to below empty and the light still dosnt turn on, but it only takes 12 gallons. id like to know
Flash75
12-19-2005, 05:35 PM
I think the tank capacity may have changed over the years. My 2004 is supposed to hold 16 gal. according to the owners manual.
The 2000 brochure indicates 15.1 gal. or 18 gal. depending on the model.
http://www.toyota.com/html/tcuv/brochures/00_tacoma.pdf
Clifton
Clifton
