aditional injector
bowtiebuba
01-01-2005, 11:11 PM
who makes aditional injector controlers or kits?
Holyterror
01-02-2005, 03:12 PM
Try RB Racing's additional injector controller (http://www.rbracing-rsr.com/rsraic400.htm). RB is where I send a lot of people for suping-up their Harleys. These guys are wizards with forced induction and fuel injection. They'll answer all your questions in their simple, no-B.S. way (which most people appreciate).
bowtiebuba
01-02-2005, 07:43 PM
thanks man
PWMAN
01-10-2005, 06:57 PM
Wow, if you want to spend that much....
I used a Cold start injector from a Junkyard Saab or old VW. $5 at the junkyard. Got a Hobbs adjustable pressure switch from Napa for $25. Mounted the injector in the pipe, tapped fuel line to injector, set the pressure switch to come on at whatever you need, run a vacuum line to it, and voila you can run about 2-4 PSI boost more for less than $40.
psychorallyfreak
01-17-2005, 09:25 PM
whoa, nice ghetto tech. But it makes sense to spend a little for the same result...
PWMAN
01-17-2005, 10:15 PM
Worked for me. The stock fuel system is good for around 14 PSI on turbo dodge's, with the 5th injector from the junkyard Saab I was running 15 PSI. I could have run 16 or maybe even 17 but I wanted to stay a little rich because I'm running stock Cast pistons.
Turbo Meg
01-17-2005, 11:00 PM
ATR makes one for several different turbo cars. I used one years ago on my Buick Turbo V6.
To be honest larger injectors, fuel pump, fuel regulator and cutom chip or ECU is a much better way to go.
The ATR unit is around $375 with contol unit, check out thier web site.
