need help with alternator problem
Google
Web AF
mudman1970
01-01-2005, 02:45 PM
Have a 1986 DL240. It will not charge the battery. Have bought new alternator, test light shows power going to the batter but still isnt charging the battery. Anyone have any suggestions on the problem and how to fix it.
thank you
Paul
RVMAN
01-09-2005, 12:31 AM
Things to check- (1) voltage across battery should be at least 12volts without motor running. (2) battery terminals should be super clean (3) pos/neg cables should be in good shape & clean (4) the alternator should be producing almost 14volts with motor running...test light not a reliable check for this,you must use a voltmeter. (5) the battery my be faulty...internal short, plate breakdown etc...this kind of a problem is a pain. Best solution is to drop by a good parts store you trust and have them do a load test on your battery. Good luck
Saskatoon
04-01-2005, 02:49 AM
Hi.
Just had this problem with a rebuilt alternator. Turns out no charging was due to a loose earth wire, so check your connections.
mjlaq5
02-17-2006, 09:43 AM
1987 240 DL wagon. I have gone throuigh 4 batteries in 8 weeks.
Alternator has been removed and tested good, New voltage regulator installed. All of the wire connection have been cleaned and appear to be tight, I have conectivity through the wire from the alt to starter and from the starter to the battery.
Voltmeter shows 14 at alternator and 13.5-13.6 at the battery with car running.
The car runs about 4 days then it won't start, the battery is dead and the first three checked out at the auto parts store as being bad wouldn't hold a charge anymore. I'm about to return my 4th battery.
Any suggestions as to what else could be destoying these batteries? :banghead:
aleekat
02-17-2006, 10:40 AM
You may be having something discharging your battery when it sits...
Look here for some testing notes.
http://www.brickboard.com/FAQ/700-900/ElectricalStarting.htm#SlowBatteryDischarge
volvotech
03-29-2006, 09:51 PM
i had the same problem I repalce 3 alternators and I end up replacing my crank shaft pulley, was separated in the middle after that the car was perfect,no more problems with the charging system was pain in the butt but now is ok
mjb0724
05-20-2006, 05:42 PM
Make sure your alternator is grounded
mjb0724
05-20-2006, 05:44 PM
Make sure a ground wire is not broken going to your alternator case--MIKE
Tom_paine1776
07-03-2006, 07:44 PM
how do you know there is electricity coming from the alternator unless you removed the terminals from the battery while it is running?
aleekat
07-11-2006, 03:08 PM
With a voltmeter. Read battery with car off. Run the car and read voltage. Should be around13-14.5. If the readings are the same, suspect alternator or associated wiring.
Tom_paine1776
07-11-2006, 03:25 PM
what if anything is wrong with removing the battery terminal once the car is started. I can tell you from experience that the car will behave normally unless it is shut off,and it is indisputable proof that the alternator is functioning.
aleekat
07-11-2006, 07:58 PM
I do know people who do it that way. But I also know folks who's computer got fried. I'll stick with the voltmeter..
TheMan5952
07-14-2006, 11:09 AM
Never heard of somone frying their computer that way, It's common practice in all the shops I've seen. It's not like computers are exspensive for these anyways, you can get them on ebay for like 50 bucks.
Not knocking the voltmeter method, I do that in addition to the other test.
Google
Web AF
