2003 fuel filter removal ???
Google
Web AF
mikemc
01-01-2005, 01:02 PM
I need to remove the old filter and install a new one. The plastic connector is nothing like the one on our '97 Cvalier. This one is a large black plastic block with a green tab. It is NOT the older type with the squeeze tabs at the end. Anyone know how to release the filter from the new style connector? Thanks.
mikemc
01-06-2005, 06:28 PM
Anyone ??????
scottbatson
01-16-2005, 12:16 PM
I'm working on replacing the filter and fuel pump. I was able to unlock the connection using a small standard screwdriver after I looked at the connectors on the new fuel pump. I inserted the screwdriver into the center of the colored lock in a gap that was visible and twisted it until the lock opened.
mikemc
01-18-2005, 05:24 AM
Thanks for replying. I talked to my dealer's service manager and he explained it to me. As you said, the green tab unsnaps ( I didn't even need a screwdriver) and then the whole green clip is pushed up and away until the filter can be removed. Reverse for installing new filter. It was easy.
Google
Web AF
