OEM Crank Pulley's lug nut !!!
BNR34_V-SpecII
12-31-2004, 07:57 PM
It is a pain in the butt to get the lug nut off from the OEM Crank
Pulley, the PowerSteering Pulley and the Alternator Pulley are perfectly
installed, but the Crank Pulley, OH MY GOD, it is WAY TOO TIGHT, only
the Crank Pulley can make the difference in hps. I've tried many places,
those guys could not get the lug nut off from the OEM crank pulley, any
suggestions anybody? thank you in advance.
BNR34_V-SpecII
12-31-2004, 08:12 PM
Help !!!!!!!!!!!!!!!!
do you guys think I should bring my car to the Honda dealer?
mjgjr72
12-31-2004, 08:17 PM
have had a few tough ones i usually end up using a torch and heating the washer between bolt and pulley while using impact intill it breaks loose, good luck
BNR34_V-SpecII
12-31-2004, 08:28 PM
will i be able to use the washer and the bolt still?
mjgjr72
12-31-2004, 08:37 PM
yes
BNR34_V-SpecII
12-31-2004, 09:14 PM
man, it is really a big frustration.
mjgjr72
12-31-2004, 09:26 PM
yup, the hondas are the only ones i have had a problem getting the crank bolts off of
BNR34_V-SpecII
01-02-2005, 07:45 PM
YES, FINALLY, i could get that out and installed the crank pulley. The reason why it was hard to get it off, it was because it never been taken off, so the dusts got clogged up, in sense the dusts caused for the bolt to be stuck.
