code 0446 evac emission wiring
Google
Web AF
job
12-31-2004, 04:02 PM
code 0446 evac emission wiring, what is it? and where is it?
ricksza
01-01-2005, 05:22 PM
DTC P0446 Evaporative Emission (EVAP) Vent System Performance
There is no way to check this at home, but could have been caused by a loose fuel fill cap.
job
01-01-2005, 08:09 PM
hey thanks ricksza i guess i'll have someone check it out. another problem that i have would be the shifter on the floor, when i put it in park and i turn the key to the off position it won't lock the steering wheel and i can't get the key out. and when the truck is off the shifter easily goes in to gear, when before it would lock. what can i do?
ricksza
01-01-2005, 10:35 PM
The key won't turn to the release position unless it knows that the shifter is all the way in park. There is a cable from the shifter to the ignition lock cylinder. So most likely either the cable is sticking or the shifter isn't going all the way to park.
Google
Web AF
