Programming remote
Google
Web AF
joelenriquez
12-30-2004, 09:36 AM
Is there anyway to program an additional remote for my vehicle for free?
ricksza
12-30-2004, 09:58 PM
What year Cavalier is it?
u2fly
02-05-2005, 01:41 PM
I have 1996 cavalier z24. I bought it with no remote.It is made for kealess remote.I bought 2 remotes FCC ID ABOOIO4T (TRW).Will they work and if they do how do I program them. Thank you.
Boomsly
02-05-2005, 02:23 PM
1. Turn th ingition switch to off
2. Jumper program connector terminal A to terminal B "door locks will
lock and unlock in approximately two seconds"
3. Press lock and unlock button on one transmitter. Door locks will lock and unlock in approximately ten seconds. The RFA Module is now programmed for the first transmitter.
4. Repeat step 3 using other transmitter if you more than one transmitter.
5. Disconnect jumper from program connector.
Hope this helps you out.
BTW The door lock receiver module is in the trunk on the drivers side. The pins are labled from A thru J 16 total. Make sure you just ground A and B together.
This was posted to help a guy that had a 96 Z24 and next time before you post asking questions try the search funtion first, theres tons of threads discussing this and almost everyone of them has this exact quide posted in it.
Google
Web AF
