SR20DET parts swappingG20ps 03-06-2002, 07:32 PM In P10DET's swap article, he swaps a Bluebird DET into a '91 P10. It says in the article that if you are swapping into a '94 or later P10, a few additional parts must be swapped. I was just wondering, what specifically are the other parts that must be swapped? (I know a few harness wires must be extended, but what else?) P10DET 03-06-2002, 08:36 PM Originally posted by G20ps In P10DET's swap article, he swaps a Bluebird DET into a '91 P10. It says in the article that if you are swapping into a '94 or later P10, a few additional parts must be swapped. I was just wondering, what specifically are the other parts that must be swapped? (I know a few harness wires must be extended, but what else?) I'm not an expert at swapping into a 94 or later car, but I know you will have to use the distributor from your car (if you have a distributor with an internal coil). I know SE-R.net has a little information on this. The folks on the SR20DE forum will have more info. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
