99 Camaro won't start !?!?
Google
Web AF
3800Maro
12-29-2004, 10:29 PM
Ok... Here is the problem I have a 99 v6 and it doesn’t want to start.
It cranks runs for a few seconds and loaps and idles very erratically.. It sounds like it is missing on a few cylinders... It is also running very rich.
I have checked Coils, ICM, PCV valve, MAS and cleaned the MAS, and Air Filter...
All these are fine so the problem is elsewhere.
I have a good idea that’s it is an ignition problem but where? I tried to run codes but the service engine light doesn’t come on and there are no codes stored.... Hence why I have a problem....
Anyone have this problem before or have any ideas... Thanks
92rs25th
12-30-2004, 12:45 AM
that sounds like some crazy shiat. Have you checked your distributor ? Do the 99's even have them ? I don't know , I refuse to work on anything over 92'. Anywho , if not , then I dunno. Maybe some plugs are shot or ( had this happen to me once on my XT6 ) some plug wires worked lose and mine boxer 6 2.7 was missing 3 cylinders , went and reclipped the wires , started her back up. banging on all 6 again. Maybe this can help maybe not.
Dark Knight
12-30-2004, 06:15 PM
Did you check the spark plugs? it sould be the distributor wiers. That also could cause the car to die
89IROC&RS
no distributor, the 99's have coil packs.
tough situation though, you seem to have covered most of your bases, the only two that leap to mind though that you missed are the IAC (Idle Air Control Valve) and the MAP (Manifold Absolute Pressure) but checking your wires for a solid connection is also a good idea.
cuda_dude
12-30-2004, 06:22 PM
i agree with 92rs25th, it could be something as simple as some plug wires came loose and cut or burnt though, it will cause the same problems.
3800Maro
01-08-2005, 08:58 AM
progress update..... It still doesnt run.... i have changed the fuel press. reg., fuel filter checked all other sensors.... today im goin to check the injectors and might change the plugs....
chevy_chic20041
01-08-2005, 05:54 PM
yeah i had one wire get burnt and the car was running like complete shit...but there was also smoke from the wire burning
92rs25th
01-08-2005, 06:37 PM
Usually if you have a burnt wire and it's making contact or arc jumps , there will be a clicking sound..the electricity arcing.
3800Maro
01-08-2005, 10:50 PM
Update 2:
Ok cleaned the throttle body and changed the plugs....
After removing the plugs 4 of the 6 still has some fuel on the tips.... So I wasn’t getting a good spark to ignite... After the new plugs were in I started it up and it ran great but slowly got worse...and then died... and now it seems to be a fuel problem and not an ignition problem as I first suspected.... Any ideas?
Then I ran some injector cleaner into the fuel rails and it started right up.... and ran as long as the injector cleaner was going thru... still will not start.... I’m lost..... Any help will be awesome....
I also check for any arc from the wires...
So a recap of today’s work: New Plugs, Checked fuel pressure (51psi), cleaned throttle body and ran some injector cleaner in the gas and thru the rails....
I have a feeling it might be the injectors but not sure.....
Genopsyde
01-09-2005, 02:57 AM
i'd be looking at the coil packs myself.
3800Maro
01-09-2005, 08:11 AM
tested them...they are good....
89IROC&RS
01-09-2005, 10:51 PM
sounds like it could be the crank position sensor. thats what the newer engines use to determine proper timing for the ignition. if that sensor goes bad then it wont run, and you will have unburned fuel on the plugs.
92rs25th
01-09-2005, 10:58 PM
I had some fuel on the end of my plugs one time but that was because I didn't torque my plugs all the way down on 6 and 8...pain in the ass to get to.
3800Maro
01-10-2005, 11:49 PM
Yea thats what Im thinking.... Now it will start when its cold more than 75% of the time now, but when it warms up alittle (about 2-3 min) it dies.... Is there anyway to test the crank position sensor and where is it located? Thanks...
3800Maro
01-10-2005, 11:51 PM
Yea those were the worst plugs I have ever changed... had to go from below and they angled them in... Pain in the a**
89IROC&RS
01-11-2005, 08:10 PM
the only way i know of to check the sensor, is to hook up the Tech2 and look at the crank position sensor data in real time. that or replace it with a new one and see if it fixes it :) as for where it is, i have no idea.
Google
Web AF
