Head Gaskets Symptoms '01 Prix
Google
Web AF
Mr.Sonoma
12-28-2004, 09:07 PM
Hey guys just wanted to know what I should look for as far as symptoms of a bad head gasket in my 2001 Grand Prix. The car has 153,000kms on it and I am told around 160,000kms it fails usually. The car loses almost no oil probably, 1/2 to 1 qrt. every 8000 - 9000 kms. Coolant mucks up a bit every once in a while, but I am also told that the dexcool shit does that. Any help would be appreciated.
Thanks
,Noma
kustomkid54
12-28-2004, 09:55 PM
Normally, you would have foam (white stuff) in the oil, if head gasket gone.
Read this forum. Read GTPDad's answer.
http://www.automotiveforums.com/vbulletin/showthread.php?t=257941&highlight=head+gasket
MIGTPGUY
12-28-2004, 11:56 PM
damn, my heat is also fluctuating when i accelerate to the 210 mark and then drops back down when i idle to an intersection. I have a lil oil leaking out onto the fron three headers. Is this a head gasket or a valve cover gasket, or are those the same. Someone said it could be a valve cover gasket. Im hoping it is not a head gasket because i dont have the money to replace it.... My car seems to be performing fine except that now that i have Intense PCM in and when performance shift is on, i notice that when im going about 50 MPH and i slowly push in on accelerator, enough to not create any boost, that my rpms will kinda bounce from 1,300 to about 1,800. Hmmm.. Please tell me i dont have a bad head gasket.. And like i said, is there a dif between head gaskets and the oil valve gaskets
kustomkid54
12-29-2004, 12:39 AM
GPs always had a valve covers gasket troubles
MIGTPGUY
12-29-2004, 01:08 AM
um ok, is that dif the head gaskets, im assuming yes, and is it gunna cost alot. and should i worry much about it if its not leaking much oil, bout a half quart every 5 k miles
kustomkid54
12-29-2004, 01:36 AM
No valve cover. Top of the head. Not head gasket.
http://img.photobucket.com/albums/v425/kustomkid54/logo9.jpg
MIGTPGUY
12-29-2004, 11:13 AM
uymmmm ok....
kustomkid54
12-29-2004, 11:30 AM
Guy,
Changed spelling.
Sorry
MIGTPGUY
12-29-2004, 12:12 PM
i totally am not following what your saying, call me dumb but sitting here at my computer im lost lol
Chazman
12-29-2004, 01:35 PM
Migtpguy:
They are two seperate gaskets
Valve cover gasket - cheap and easy
Head gasket - not so cheap and much more involved.
Chameleon-kat
12-29-2004, 01:46 PM
And don't forget intake manifold gaskets depending on what year and engine
MIGTPGUY
12-29-2004, 02:38 PM
thanks chazman, all that needed to be said.... i hope its just a valve cover gasket. Like i said, its leaking onto the front 3 header pipes.. so im guessing valve gasket
Chazman
12-29-2004, 03:07 PM
Oil generally travels down not up, your valve cover gasket is above the three pipes, head gasket below.
Sounds like the valve cover gasket to me.
MIGTPGUY
12-29-2004, 09:46 PM
yeah, there is not one drop of oil leaking onto my driveway... its all on the three headers and its horrible because once the three header pipes get hot, it burns that oil on them and stinks up my ride. Hows a man to get any ass in his car when the shit smells like burnt oil?!?! ;) and thanks chazman, i dont know shit about the gaskets as im not that into cars , im still trying to learn about GPs and cars in general, so im hoping its a valve cover gasket. any idea how long it would take a master certified mechanic to fix it, cuz i have a buddy that does shit for me for about 20-30$ an hour. and if i have valve gaskets replaced, would it be feasible to go ahead an put the new NGK spark plugs i have in???
Chazman
12-29-2004, 11:32 PM
The front one should be a piece of cake, the rear could be alot harder, I'm not familiar with that motor, and how things are layed out in the engine compartment.
Once the oil leak is stopped, I would give the engine a good degreasing, then replace your plugs.
MIGTPGUY
12-30-2004, 12:01 AM
yeah, i have little money to spend on repairs, every repair i have to do to this car is money that could be spent on a mod, and i just got the car 2 weeks ago, traded my friend my 98 GT for it.
troy1
12-30-2004, 02:23 PM
my 95 3.1L temp gauge does the same thing and I am almost positive I dont have a bad head gasket. Dont know why the temp gauge moves T-stat maybe (put a new 195F in it I think I got all the air out)? or leaky lower intake gaskets any Ideas guys?
troy1
12-30-2004, 02:24 PM
Car does not seem to use anitfreeze FYI
Chazman
12-30-2004, 02:31 PM
Sorry troy1, I am getting lost, maybe it is time to start a new thread describing your problem.
MIGTPGUY
12-30-2004, 02:39 PM
hes talking about his temp fluxuating
Google
Web AF
