4x4 PROBLEMS SOMETIMES WONT WORK
Google
Web AF
MJTrippy
12-28-2004, 01:34 AM
okay heres the deal, have a 95 chevy blazer, and sometimes the 4x4 wont go into 4 high, or low,it could be a good week till it mess;s up, when i go to switch it to 4high no light at all will turn on, to get the lites to come back on i have to put the car n N then click 4 high or low and bloth lites flash 3 or 4 times then both stay lit, then sometimes i unplug the computer 2 the 4x4 in the dash for a sec it works like brand new again other times i have to let it sit over night to work again....... dont know what to do.....( oh yea and sometimes when drivin down the road with 2 high the lite shuts off and 10 min later comes back on) dont under stand need help lol,,,, thanks guys
uxguy
12-28-2004, 09:59 AM
The Lights flashing when the button is pressed generally means that you are trying to switch at invalid times. Can't remember the specifics. but to switch from 2 high to 4 high, you must be in park, or in neutral running under 15 mph (I think). Also, to switch from 4high to 4 low, must be in park, or neutral nearly sitting still. I haven't noticed any problems switching back to 2 high as long as it is in park, or neutral at a decent speed.
My 2 high light would also come on and off on occasion, but I think is it a faulty bulb rather than an indication of the 4x4 system. My light no longer lights up at all...
hope that helps
stanwood
12-28-2004, 11:10 AM
A couple of things I did with my 97 was I found the relay behind the glove box that controls my 4WD and I re-seated them that solved my problem for about a year then I recently took it in for repair and they found the large electrical connector to the firewall was loose. It is held in with a bolt and they turned it only about a turn and a half, but it seems to have solved my 4WD problems.
GoBears
12-28-2004, 04:27 PM
My 93 Blazer had the exact same problem...turned out to be the encoder. Hope this helps :) By the way you can switch from 2Hi to 4Hi in any gear and while in motion. To go into 4Lo you must be stopped and in neutral.
MJTrippy
12-28-2004, 04:41 PM
now when you say behind the glove box you mean in in the glove box or take of the back peice in the glove box and in there?????? oh and when just driving down the road and the 2 high lite goes off, none of the buttons do anything when you press them, the only way they attempt to work is when the car is in N.......then i get both 4 high and low to flash 3 times, and sometimes both come on lit and other times stay off
need more ideas thanks guys
GoBears
12-28-2004, 07:20 PM
Like I said mine was doing EXACTLY the same thing...right to the T. When the encoder goes bad the computer has no idea what position the transmission is in and cannot determine when to engage the transfer case. That is why your lights are blinking.
MJTrippy
12-28-2004, 11:12 PM
well i guess imma buy a encoder motor sence i guess thats whats bad.... anyone eles got one for sale or know where to get one cheep???
let me know thanks guys
Google
Web AF
