Where is the fuel pump relay? 86 F-250charman420 12-27-2004, 05:41 PM My truck died driving down the road, and now it won't start. I checked spark plugs and thats all good, took the fuel line off the pump and no gas was coming out, so i tested the power to the fuel pump and there was no power, so I'm guessing that it's the relay, but i have no idea where it is? Any help would be greatly appreciated. Thanks, Sean Paul Masley 01-02-2005, 03:16 PM The relay should be behind the kick panel at the right door. Crane your neck and look up. You can just barely see the top of it. Make sure the key is on when you reset it or it won't work. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
