2004 Venture wind vibration sound from under the hood.
Google
Web AF
Pusa
12-27-2004, 05:02 PM
I recently bought a 2004 Venture and found that it makes a very annoying high pitched whine from under the hood when traveling at about 65 mph. It almost sounds like a bad bearing on a small fan or motor. I'm certain that it is from some kind of wind vibration because I've heard it while driving into the wind at about 30 mph and have heard it go away while turning with the wind at 70. It's not the wipers. I have a tight schedule and don't want to have to take it in to the dealer if I don't have to. Any input will be appreciated. Thanks.
JP
rboatwright
12-27-2004, 09:47 PM
I have the same problem and have not been able to find out where it is coming from. I put tape on the windshield, on the window seals and even on the plastic where the air intakes are. I thought it solved it, and was going to start removing tape until I heard it again. Before I could take any tape off it happened again. It seems to only happen when there is a strong crosswind. I also noticed that it seems to stop if I roll down the driver window when I hear it. So I am thinking that maybe its an issue with the door seals. The van is still under warranty, but I dont have another car and cant afford to leave it at the dealer for a week while they try to re-produce the problem. I hope others have heard of this problem and know if there is a solution, that would help with the dealer since I can then just tell them what needs to be fixed. I will continue trying to determine which seal is vibrating in the wind and causing this horrible whine.
AJT1961
12-28-2004, 05:02 AM
Pusa, are you absolutely sure it's a wind noise? Mine made an annoying very high pitched--low volume whine when the front right wheel hub/bearing assembly started to wear out. I was able to rule out an engine noise by shifting into neutral at highway speed to let the engine run at idle speed, which did not change the noise. Turning the wheel did affect the noise, however, as did travelling at different speeds (It only made the noise at speeds over 50). Dealer part price for a new hub was over $300, not including labor. I bought a new aftermarket hub for $100 and replaced it myself in about an hour.
Pusa
01-10-2005, 06:16 PM
My car has only 6k miles so I would hope it's not a worn part. Since the noise happens at a variety of speeds, depending on the wind speed and direction, the only seeming common thread would be the speed of the wind across the hood or through the engine compartment. I don't have a garage to work in and Chicago is somewhat cold and inhospitable at this time of year, so it may be weeks or months until I am able to put any real time into solving this. The noise seems to eminate from somewhere in the center of the engine compartment just on the other side of the firewall. I haven't tried tape but I thought I would by starting with the insulation on the inside of the hood. I'll also have to check where the hood seals in front of the windshield. I'll keep you posted in case I solve this myself. If anyone comes up with anything before then it would be greatly appreciated!
Thanks!
shooter72
01-12-2005, 04:22 PM
I have a 2004 Venture that my company has me use for service calls and I have the same noise that all of you have from under the hood at about 60 miles an hour. It gets even worse in a cross wind. Have been to the dealer twice and they cannot find the problem. Any suggestions would be appreciated. This is company leased van so I am not allowed to do anything to try to resolve the problem. Now the dealer wants me to bring it in again so the service manager can try to hear the problem but I don't have the time. Any suggestions would be greatly appreciated.
rboatwright
01-13-2005, 02:22 PM
After talking about this with some others, the noise shows up on other chevy cars and pontiacs. There is a thought that it could be coming from the internal air filter. His car does it at ~75 mph, my van does it at ~65 mph with a high crosswind. We are thinking that the air is getting forced into the filter too hard and causing a kazoo effect on the filter. I am going to try removing the interior filter next time I hear this happen. I have not yet taken it to the dealer since its very hard to re-produce. If there is not a crosswind, it doesnt do it.
andrewandalicia
02-23-2005, 07:48 PM
My venture is dong the same thing! The whistling noise sounds like it is coming from the driver's side windshield area maybe around head high area! I've seen a few replys about the crosswinds etc... I noticed when it's very windy out it can be pretty bad. This noise is so annoying!! But I would have to agree about the windshield seal or door seals, I don't think it is coming from the engine. Please help if anyone knows anymore.
Andrew
Kevcules
02-23-2005, 10:17 PM
Steady as she BLOWS!!
What a surprise , yet another COMMON problem with the venture. If you guys and gals still have warranty, take it in and get a "replacement" vehicle untill they solve the problem. Good luck to you.
Kevin
rboatwright
02-24-2005, 07:44 PM
I am taking my Venture in next week. Its still under warranty and the dealer here is really nice, I am hoping they will replace the window seal.
Andrew
Papaw
03-05-2005, 10:47 PM
I have a 2004 Venture with the same problem--I think. I've had it to the dealer 4 times so far. I can get the noise to stop when the windshield wiper is at the 12 o'clock position. It stops and then starts when it leaves the 12 o'clock position. However when I use the washer it goes away for a long time. I'm taking it back to the dealer next week.
rboatwright
03-06-2005, 08:17 AM
What has the dealer done for you at thig point? I have replaced the seals that hold the windshield in? I will finally get mine back into tht edealer this week, I was going to request that they just replace the seal. I also had the venture just stall at a light. Was rather odd, it has never done that before and it started right up. I was really wondering what they have done so far for your venture so I can tell them that it probably wont work.
THanks
-Ray
Papaw
03-07-2005, 01:15 PM
They had a glass company check the seal out--nothing happened. After the 3rd trip to the dealer, they said ther found a bulliten taht said the problem was the seal between the firewall and the passinger area. They did some kind of seal job and it reduced the noise but it was still there aand it has increased. When my Wiper is at the 12 o;clock position it stops. When I use the washer it stopps for quite a while, so I think it is either something to do with the wiper/ washer or the seal on the left side of the windshield or door. Good luck.
THanks
-Ray
Papaw
03-08-2005, 08:39 AM
I have my car at the dealer right now. They said thee was a new bulletin out and they will see if that will fix it. He couldn't tell me whath bulletin said as it was late last night when I took it out. I'll let you know the result.
rboatwright
03-08-2005, 09:16 AM
Cool. Yeah let me know how it goes, then I will take the info to my dealer. Has your venture ever just stalled at a stop?
Papaw
03-08-2005, 04:06 PM
I just got my car back. There is a new bulletin # 02-08-58-005B that was issued 2/08/05 . I saw a diagram but con't understand it. The work order says "Seal Body seam under Cowl" Have your dealer check that bulletin. I drove my car and didn't hear the noise, but I didn't always hear it. It depends on the wind speed and direction.
Good luck
ace395a
03-09-2005, 04:33 PM
Check out the subject "Wind noise fix" just a little further down in this forum. I think this should help you solve the problem. This particular problem and fix doesn't seem to be in the dealer system yet.
Papaw
03-09-2005, 10:45 PM
Good luck
Well, I drove my car today in strong wind coming from the west. When I turned toward the west the nosie came back, but it was steadier than before. When I turn the windshield washer on it will stop for at least a 30 min.
Papaw
03-09-2005, 10:50 PM
I got the following message from another person that I have had some info regarding this issue. I will check it out and thought you might want to also.
mikstevin
08-10-2005, 12:26 AM
My venture has stalled on me approx. 6 times. Most of the time it happens when I am turning into a parking spot and it has stalled a couple of times as I am cruising to a stop. My venture is a 2004 and my dealer says to me that because it is not a consistant problem they can not do anything.
I can guarentee that when my lease is over I am done with this van.
rmw1947
01-31-2007, 08:58 PM
I recently blocked off my rad completely with a house for sale corrugated plastic board ( it was very cold inside )and the noise stopped even at 80mph. i believe it stops air from entering at rad and exiting just below windshield at the seal between cowl and just below wipers. vibrating noise may come from seal or wipers. i too tried everything but gave up then stumbled on this by accident.in the summer will drive with wipers at 12 position ( pull the fuse ) to see if it is the wipers.
cjstew4
02-01-2007, 01:01 PM
My 97 sometimes stalls when I come to a stop (every 4-5 months), but mostly when it's a quick stop. It stalls more often ( 2-3 months) going down this big hill from my house at the bottom going about 35-40 mph curving left as I am braking, but not always when I am braking. I just shift it to NEUTRAL and restart it, put it into DRIVE and proceed.
richfitch
07-21-2007, 03:34 PM
Good luck
I suffered this problem with my 2003 Venture until I noticed a rubbing problem with the back wheel cowling on the passenger side. I had to put in a screw to avoid rhe loose cowling and a wonderfult thing happened. The high pitched squeeling went away. So check the cowling arounf the tires as it may be the problem.
'97ventureowner
07-21-2007, 08:41 PM
richfitch- Welcome to AF ! Please check the dates of the threads and try not to resurrect those over 3 months since the last post date. Feel free to start a new thread if you have some new information to add. You can even link to the old thread if you feel it is applicable.
Thread closed.
Google
Web AF
