best tires for tracker
Google
Web AF
kingsage83
12-27-2004, 03:43 AM
i have a 96 tracker 2dr 4wd
what are the best all season tires for this car?
thanks
Phu
12-27-2004, 05:37 AM
thanks
My advice would be to find a tire size you want to go with, OEM or otherwise, then hit up www.discounttiredirect.com (america's tire company), www.tirerack.com and any other online tire supplier you know of and look for the size tires you want and read every single review. I was going to go with Nitto 555 255/35/zr20's until I read everyone's reviews that said they have 0 wet traction.
Checking out performance stats and user reviews is the best way to find the right tire as it also depends on your driving style and purpose of the car.
If you're going to change the size of the tire or wheel/tire and you don't want to have your speedo adjusted I suggest you do the following:
Find the tire you think you like,
Go to the manufacturers site and pull up the tire specs,
Check the diameter of the tire. Stock is about ~26.7"
The Hankook Ventus Sport K104 245/35/ZR20 is 1/4" smaller in circumferance than the oem tire. I lose 4"/mile. No speedo adjustment needed. Keep that in mind. Cops won't let you go on a speeding ticket because you never got your speedo recalibrated.
-Wayne
93trac
01-01-2005, 03:05 PM
I put 235/75/15 on mine and it and it runs great. And the speedo is right on
Google
Web AF
