1997 Grand Prix won't start, battery fine.
Google
Web AF
jlaycock
12-26-2004, 03:18 PM
My 1997 Grand Prix SE won't start. Battery is fine. When I turn the ignition, it sounds like it's starting to turn over, then I hear a few clicking sounds and the power goes dead. Clock resets to 1:00.
Electrical problem? (FYI, it's about -5 degrees Celsuis).
kustomkid54
12-26-2004, 03:24 PM
I'm going to take it you had the battery checked. It sure sounds like that would be it. At 5 below a battery has to work hard to turn any motor over. May want to bring it inside to warm. With the clock restting, you are losing power.
I hate weather.
http://img.photobucket.com/albums/v425/kustomkid54/Christmas2004001.jpg
Chazman
12-26-2004, 03:35 PM
I would load test that battery.
It may show 12 volts on your meter, but if it pulls down below 9 when attempting to start its pooched.
May want to check the connections at the battery and starter as well.
JonJon68
12-26-2004, 06:57 PM
Yea, i had the same problem and the connections were loose. Tightened them up and no probs since
jlaycock
12-29-2004, 05:46 PM
Well, I'll end the suspense. It was the battery after all. Replaced it and the car starts without a hitch. Thanks for the suggestions everyone.
Google
Web AF
