freezing doors04_CaV!! 12-26-2004, 11:16 AM Ok, I know everyone who owns a 95 to 05 cavalier has had this problem at one point or another, freezing doors. I used to own a 94 cavalier and I never ever had a problem with freezing doors do to the door lip design. My wife owns a 2000 cav and I now own a 2004 cav and both of us have the same problem. If any condensation or rain water falls on the car and the weather turns really cold the doors freeze shut tighter than virgin on prom night. I have tried keeping the seals lubed with everything from wd-40 to protruluem jelly. Nada! My question is what have you all done to keep your doors from freezing? jayson716 12-26-2004, 11:21 AM Garage lol jayson716 12-26-2004, 11:21 AM But yes even went it is dry out and very cold here they do stick. Thepoet125 12-26-2004, 08:33 PM living in PA as you do, I know of this problem, I use petroleum jelly, and it works just fine, just make sure to lube all surfaces that touch and there is no rubber touching together. Classicrocjunkie 12-26-2004, 11:17 PM living in PA as you do, I know of this problem, I use petroleum jelly, and it works just fine, just make sure to lube all surfaces that touch and there is no rubber touching together. This just sounds terribly wrong to me... all the talk about lube and touching... LOL... ......anyways... i get them sticking too. But usually i can just get them to open right up. Other alternative is luke warm water and pour it around the edges. Don't make it too hot or there is a chance you could crack the window. KustmAce 12-27-2004, 02:43 AM Get some de-icer. 04_CaV!! 12-28-2004, 07:44 AM yea de-icer works well only if your at home and you can go in the house and get it. That won't work too well if your at a friends house, running late for work because the weather personel stink at doing their job. Garage only works if you can fit the dame car in it. lol and remember the question was to keep them from freezing not what to do after they already froze. That I can figure out. I am just seeing if there is something to do so they don't freeze in the first place. 02cavy 12-31-2004, 05:25 PM any suggestions for freezing locks? my doors freeze as well, but that doesn't upset me as much as when my locks freeze and I almost break my key tryin to get in. I've tried those little lock de-icer things with basically no success. any suggestions on what to do about this?? (i also live in PA...maybe we should just move south!) 04_CaV!! 12-31-2004, 06:34 PM any suggestions for freezing locks? my doors freeze as well, but that doesn't upset me as much as when my locks freeze and I almost break my key tryin to get in. I've tried those little lock de-icer things with basically no success. any suggestions on what to do about this?? (i also live in PA...maybe we should just move south!) and leave all these twisty back roads, to open up the ecotec! NEVER.... unnnnnless someone pays me the right price for my house...lol jayson716 12-31-2004, 11:01 PM WEll keyless entry works for freezing locks. KJRich 01-01-2005, 09:13 AM You should spray WD40 or something of that type in the locks to prevent freezing. KustmAce 01-01-2005, 04:53 PM To prevent the doors from freezing, Ive heard if you smear the seals with vaseline they wont. Mark E M 01-02-2005, 12:45 AM Sorry guys, over time the petro jelly will attack the rubber over a period of three or four years, and turn it rubbery mess. WD/40 is ok, bur spray silicone, sprayed lightly on the door jams,and wipe excess with a rag. then spray all rubber seals and wipe off lightly... will last about a month or two, then do it again.Ido this when ever I wash my car. Hope this helps. Later mark. Mark E M 01-02-2005, 12:46 AM Sorry guys, over time the petro jelly will attack the rubber over a period of three or four years, and turn it rubbery mess. WD/40 is ok, bur spray silicone, sprayed lightly on the door jams,and wipe excess with a rag. then spray all rubber seals and wipe off lightly... will last about a month or two, then do it again.Ido this when ever I wash my car. Hope this helps. Later mark. also works on locks, displaces moisture... Later Classicrocjunkie 01-02-2005, 12:55 AM for the locks they have a deicer spray thats in a can and you just squirt it into the hole.. 04_CaV!! 01-04-2005, 01:37 PM thanks for all the hints... I have tried PJ only to have it wind up on coats and the paint job and boy is that a bugger to get off after a long winter. And not to mention the really, really tite seal it makes between the door and the jamb. (it's almost like it is still frozen I thought I was going to pull the handle off the dame car.) WD-40 will still freeze if it gets cold enough. (it's happend to me) The only thing I haven't tried is sillicon spray. I now have an automatic car starter which solves all the problems from stuck doors to iced up windows. I just start up the car from my nice warm house. <<< worth it's weight in gold (if it's done by a pro like mine was). jayson716 01-04-2005, 05:29 PM I agree But i think the garge is still better lol... i need a remot starter for my car and then a remote for the garagedoor to open and pull my car out for me so when i go out my door it is sitting already to go...lol but anyway a starter is a nice thing to have vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
