Electrical problem. Blower motor, dash lights & Driver Information Center
Google
Web AF
ml_nelson
12-25-2004, 10:12 PM
I have a strange set of electrical symptoms affecting the Driver Information Center and blower motor. This intermittent problem shows up on cold days when the car has been sitting turned off for a while. It goes as follows:
If the fan speed switch is turned to 1 or 2, you can hear the blower cycle up & down in speed. Synchronized with this, the intensity of the Driver Information Center goes up & down (I think the other dash lights stay bright). If left alone, for 15 seconds or so, this will go through a few cycles of voltage swing & then the Driver Information Center will go completely dark & reset and headlights switch off if it’s night-time (car has auto headlights).
Turning the blower speed off, or quickly turning it all the way up will stop this effect.
Thoughts?
empathydude
12-25-2004, 10:15 PM
lots n lots of posts about the blower moter, most end up with the resistor going bad OR the ignition switch coroding to the point of non-conductivity. my bet is with the ignition switch and its not that hard to replace with avg skills...
ml_nelson
12-26-2004, 10:26 AM
I know the symptoms for the blower-motor resistor going bad (been there, done that), but had not thought of ignition switch. I guess ignition-switch is a viable explanation if there is in fact one set of contacts in the switch that are responsible for Blower, DIC (but does not also power other key items that I would notice, ie; radio, ignition, etc).
Does anyone know the layout & utilization of contacts in the ignition switch?
kustomkid54
12-26-2004, 10:40 AM
Have you had it scanned yet?
http://img.photobucket.com/albums/v425/kustomkid54/logo9.jpg
BIG-L
12-26-2004, 03:05 PM
You might take a look at this thread and it should help you out,since it sounds like you are having problems with the Ignition switch harness.
http://www.automotiveforums.com/vbulletin/showthread.php?p=2279687&highlight=replacing+ignition+switch+harness#post22 79687
~Larry~
Google
Web AF
