Going In To 5th Gear The Car Shut Off(911)bullitt5048 12-24-2004, 03:41 AM Cars Engine Reved Down Lil By Lil To Idle Then Turned Off Battery Fine Lights Fine Cranks But Doesnt Turn Over No Signifigants Check Lights Turn On Just The Ones When You Have The Key In And All The Way To The Right B4 U Turn The Car On Tune Up Down About 3 Weeks Ago Oil And Air Filter Spark Plug Wires Spark Plugs Cap N Rotor Worked Fine Up Till And No It Didnt Run Out Of Gas How Ever Every Gear I Tryed To Put The Car In Didnt Effect The Rpm At All So Im Thinking It May Be Tranny Work That Is Needed Or May Be Cluth Cable Dont Know Yet How Ever While I Was Pulling Over Second Gear Dint Put The Rpms Up A Lil But Then Came Back Down The Tow Truck Man Said May Be Spark Or Fuel Delivery I Think May Be Tranny What Do U Guys Think? Any Input Would Be Greatly Appriciated bullitt5048 12-24-2004, 03:55 AM Also It Has 307000 Miles On It Nothing Major Has Gone Wrong With The Drive Train bullitt5048 12-24-2004, 04:25 AM dont think its the tranny bullitt5048 12-24-2004, 04:26 AM from a few othet forums im thinkin it might be the timing belt or the ignition control module but please correct me if im wrong Mike Gerber 12-24-2004, 03:04 PM As the car was running and then it started to lose power I would be thinking fuel pump first. A simple check without any tools would be to take the gas cap off and turn the ignition to the on position. Now go to the gas cap area and put your ear by the gas cap area and listen for the wine of the fuel pump. Chiltons or Haynes will give you more sofisticated checking procedures. 300,000 miles is an awful lot of miles. Is this the original fuel pump? To check for the timing belt, you can easily do one of two things. Either take the distributor cap off and have someone crank the engine. If the rotor moves the timing belt is OK. Another simple test for the timing belt is to remove the oil cap and peer down the cam cover while someone cranks over the engine. If you can see the cams turning, then the timing belt is OK. You can also check for spark by pulling one of the plugs out and reinserting it into the spark plug wire. Now have someone crank over the engine while you hold the plug near some metal protion of the engine block. Do not hold the spark plug itself, only the rubber boot portion. Do you see a spark? Good luck with the problem. Mike bullitt5048 12-24-2004, 03:44 PM will check Mike Gerber 12-24-2004, 04:55 PM Also, when was the last time you changed the fuel filter? They can clog up and stop flow of fuel to the engine. Mike vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
