1995 305 idling high
jvc1995
12-21-2004, 05:02 PM
I have a 1995 chevy C1500. I recently replaced the engine w/one that was used. I did however reuse all of the modules and tbi and distributor from my original engine. Now I cannot get the engine to idle correctly. I set the timing per the chiltons manual at 0 degrees with the set timing connector disconnected. The engine idles too high. I believe it is idling around 1500 rpms. Any ideas as what to check next?
2000CAYukon
12-21-2004, 05:04 PM
Did you replace the TBI gasket? On my 90 GMC when I had a high idle, it was the TBI gasket.
Also check for any broken or cracked vacuum lines.
//2000CAYukon
jvc1995
12-22-2004, 09:03 AM
I did not replace the gasket, however I have checked for cracked lines. I will give that a try. Thanks
jvc1995
12-26-2004, 06:45 PM
2000CAYukon
Just wanted to say thanks. I replaced the gasket and it idles great now. Thanks for your help.
